ESS Centrifugal Mustang Superchargers
TEXAS HEAT
TEXAS
2019 Mustang GT PP1 A10
It help over 15 psi of drop from 66 to 51 now it just stays 66-65
Is this the pressure drop that occurs as the rpm's increase or did it also help with the pressure drop at the onset of the pull?
hoss_s550
Wake Forest, NC
Cj
2020 PP1 Mustang GT 10r80
Those who are pushing the limits on stock fuel system . I did VMP fuel rails today and it help my pressure drop greatly. I’ve heard rhe 18+ rails don’t flow that great with these new rails totally different car.
I actually just ordered division X rails today. That's good news... wanting to do e54 tune
TEXAS HEAT
TEXAS
BoostN IT
OH
Drew
2015 Ford Mustang GT Premium
My pressure drop was just as rpm went up mostly the last 500-700 rpm
You think Gen 2 Fuel rails are okay? Just gen 3 needing upgrade.
kenand1988
Phoenix, AZ
2020 Mustang GT
VMP boost a pump
How did you relieve the pressure in the rails? Can you run them dry I guess that would be ideal. I've tried disconnecting fuel pump module and the fuel pump itself and the car will still idle.
Brad1810r80
Huntsville AL
Brad
2018 Mustang 2018 F150
I’ve pull the fuse and crank the car till it dies and I’ve just un done the rails without doing anything. Not much fuel comes out. I put a towel to catch it.
kenand1988
Phoenix, AZ
2020 Mustang GT
I've looked for that fuse do you remember it's name?
kevinvan6000
Ontario
2020Mustang GT
If anyone is looking for an affordable set of fuel rails, take a look at the Boomba Racing kit. Its on sale at the moment for $175. For the 18+ cars, you need to order an additional 8an ORB to 3/8" adapter for either the feed from the tank or the High Pressure connection as well as an adapter to convert one of the 1/8 NPT ports for the fuel pressure sensor. I got both mine from Radium for $35
https://www.boombaracing.com/mustang-gt-fuel-rail-natural/
Radium PN 14-0359 FP Sensor fitting
Radium PN 14-0368 14-0368 8AN ORB to 3/8in SAE Male
http://www.radiumauto.com/NPT-National-Pipe-Thread-Fittings-P626.aspx
hoss_s550
Wake Forest, NC
Cj
i got the BPS/Divisionx for 379 shipped using a discount codes. includes plumbing for stock lines and you can upgrade to return style later. Wish i would have known about the boomba setup though.
