Tomster
Beware of idiots
I remember when this issue came up a long time ago. I believe the fix was push it back on and use a tie wrap.
Thats correct TomsterI remember when this issue came up a long time ago. I believe the fix was push it back on and use a tie wrap.
Wanted this to be a reminder to everyone to check theirs if they haven't done so or gotten around to it. Don't want anyone to end up in my situation. Could've ended badly if it happened during a merge on a fast highway.I remember when this issue came up a long time ago. I believe the fix was push it back on and use a tie wrap.
Add mine to the list that the line was not seated properly. Never came completely off. Thanks for the heads up!Please check your lines. My line to the clutch master cylinder popped off during a redline shift from 1-2, sprayed fluid all over the back of the hot engine and a small fire resulted. Luckily it went out by itself by the time the Fire department came by. Took over a month going back and forth with Ford before they approved all the repairs, and included a new clutch. Still currently sitting there even after repairs due to o2 sensor going out and on back order. I think the total time for just various repairs has totaled over 6 months in the shop over a 4 year period. Needless to say, I am not confident in keeping this car past the extended warranty period unless it goes the next 4 years without a hitch. It's unfortunate there is no other car like it in the world. I think if I wanted the same kind of engagement and feel, it'd be a GT3 at over 3x the cost. I will say my car is practically new from all the things that have been replaced.
If I remember correctly, it came like that from the factory. I'd still just keep an eye on it once in a whille.just found mine was not seated correctly. pushed it on the rest the the way and i could feel it pop into place. there is a fair amount of tension on the cable. is this something thats keeps coming off as you drive or did the factory just not install it correctly?
exactly how mine was.Just like this
