Ecoboost in DS autoX
BoostedMike177
black ecoboost
Hey everyone!, I'm running my 16 Ecoboost in D Street and had a few questions. I'm running my stock premium wheels and thinking of running a 265 wide tire but not sure if it will rub or not. Also wondering if anyone is running competitively in DS on a Nation SCCA autoX level. Thanks!
DickR
Raleigh
Find Des Toup's posts this year in the F Street thread.
destoups
Portland
Des
Crimson red EB PP 10A
[MENTION=9216]BoostedMike[/MENTION], hi. It would depend on your wheel width and offset. The performance package has 9 inch wheels, and I've been running 275s and, currently, 285s with a 3mm spacer, so the 265 would fit fine.
Premium wheels, those are, what, 8 inches wide? A 265 might be a little much for the wheel. But I don't believe you would rub.
I am not terribly competitive but my co-driver did quite well in the car (podium at Nats). It was the only EB at Nats both years I took it, but I have seen three or four at regional Tours and Pros.
BoostedMike177
BoostedMike177
black ecoboost
I believe they are 8in wide. I'm actually thinking of going with the 17in base model wheels for cost saving on tires. They are 7.5in wide so maybe a 255 is about as wide as I'm going be able to fix. I now have two sets of the 18in premium wheels so I'll see if I can trade one set off for the base ones.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
You can always run narrower tires on wider wheels, but if you buy a 7.5" wheel you're stuck with narrow tires.
If 20x9" foundry wheels were a standalone option, you could run a 19x9 legally.
DickR
Raleigh
Here is the 2016 order guide wheel info. Since you said stock premium wheels NightmareMoon is correct regarding the 20x9 wheel option. Per SCCA rules that means you can drop down to 19x9 which is good for performance BUT sticky tires aren't going to be cheap. Note that if you intend to be serious you need to pay attention to the wheel offsets compared to which ever stock optional wheel you are basing the competition wheel on.
[/url] [/[/IMG]
destoups
Portland
Des
[MENTION=9216]Boosted[/MENTION]Mike, getting out there and having some fun is the priority. Do what gets you seat time.
My concern with 17s is that you could wind up with even more compromised gearing (already an issue on EB manuals) or too much sidewall flex.
On 275/35s you've got a 26.6 diameter and about 58mph in second gear. The 255/40/17 is 25 diameter and about 54 at top of second (and it'll stop pulling hard a few mph before that).
Going with a 45 series might get you back some of that but then sidewall flex might be a problem.
jrock
The
2016 Blue EB
I just bought some EB PP wheels. They were on sale at CJ for $316.00 a set with sensors last week. I just plan on using tbe 255/40 19 Firestone Firehawks. Last year I was using the All season tires and had some really slow times...
BoostedMike177
BoostedMike177
black ecoboost
I have ran three events on all seasons. They suck hands down but, I have paxed 26th, 21, 20. That's with a hand full of pro guys there, I'm definitely aiming to be competitive at a National level. I'll keep an eye out for 19x9. Can I run the GT PP wheels? I'm not sure of there offset compared to the EB PP wheels.
destoups
Portland
Des
[MENTION=9216]Boosted[/MENTION]Mike, the GT uses the same size front wheel (same offset, too) but a wider rear with a different offset.
Nothing will make a bigger difference than tires — except the seat time that gives you the confidence to use them to their full potential. Good luck!
BoostedMike177
BoostedMike177
black ecoboost
Sounds like I'm putting out big money for the 19s then! Thanks!
kz
West Chester, OH
Mustangs & F150
You can't run GT PP wheels and stay in Street Class. Only what you could potentially get as a package on your car and you have to get entirety of the package.
BoostedMike177
BoostedMike177
black ecoboost
I can run the 19Ă—9 but not the 19x9.5 that comes on the rear. You are aloud + or - 1in in Dia and + or -7mm offset. The ecoboost has a 19x9 wheel option in the track pack I believe.
