6g4me
Hi all,
Long story short: all my rear subframe bolts are out, and I cant lift the subframe back up without lifting the car, need help
Details below:
While attempting to install Steeda's differential bushings-- to make a long story short-- i ended up unthreading completely all four bolts holding up the subframe :frusty::frusty::frusty::frusty:
I knew that if this happened, things would be pretty bad, and it ended up happening. Before you wonder why I'd ever do this: for the front differential bushings, I didnt have enough clearance to insert them because of the fuel tank.
I kept loosening the rear as much as possible to give me enough room (front bolts are out) but the bolts ended up coming out and my subframe now hangs (its supported by jacks and jackstands currently). For the record, if anyone has the same clearance issue-- this still doesnt give clearance, the rear of the subframe is heavier so it actually tilts back and decreases your clearance.
Anyway, so in attempting to jack the subframe up here are the issues:
1. the front of the subframe can be jacked up, but if bolted up, the rear isnt aligned. Also, while attempting to re-jack up the front, the hole isnt lining up as it did previously. I also have the steeda alignment kit so ideally id like to match up with those bushings.
2. Supports where you can jack up the rear sit alot higher in that I need to place wood under my jack to get it that high, which is actually not too big a problem. However, when jacking the rear, the front of the subframe exerts force on the car and lifts the car off the two rear jackstands that support the body of the car.
3. Currently I have one front bolt in, and everything is misaligned but when trying to jack up the rear of the subframe recently, the car began lifting again off the jackstands-- this time, the front of the subframe is not touching the car at all so I have no idea what is causing this issue.
4. My issue with tilting the rear or front of the subframe too much is that the joint between the driveshaft and the differential starts bending upward or downward and it seems excessive, and honeslty just, scary.
So my question is, overall, my four bolts are off the subframe, how do I jack up the subframe without lifting the car off the main jack stands and get the damn thing bolted back up onto the car? Also what is causing the car to lift? The shocks? Springs? SInce the subframe is completely off, do I need to dissassemble shocks or springs first before I can put it back on-- is that how the car assembly works?
Im so lost. And what sucks is at the end of this, I still wont have the differential bushings in. Someone suggested unbolting the strap on the fuel tank-- questions on that will come in another thread.
ANY THOUGHTS or advice are welcome please! :headbonk:
Details below:
