Dropped hood liner plastic pin into bay.
TrainedS550
Georgia
charles
2015 mustang gt premium
Hey guys, when removing my hood liner I had one of the plastic push pins fall into my engine bay. Pretty sure it fell to the bottom. Should I be concerned about it? I tried bouncing it out by bumping the bottom liner but wasn't able to. Thanks ahead.
Whitest Russian
Southern California
Alex
2020 GT Premium
It won't do anything and you won't hear the noise inside of your car.
If it doesn't fall out by itself you'll need to get your car lifted and take off the engine debris shield, I believe it's only 6 or so plastic clips and 12ish screws.
David Schmidt
North Carolina
David
2018 GT Premium MT82 PP1 401A
And be prepared for all those battery push pins to fall out when you drop the shield too... and your 10mm socket... and and and...
W.O.T. Stang
Jim
2019 Mustang GT Premium PP1 401A
Clip, Insulator (a)W705002 S300
Here is the part number if you are interested in a replacement.
Roger Blose
Fairfield, CT
Roger
2018 Mustang GT, 1988 Mustang GT, 2009 Lincoln MKZ
Yes I dropped a battery cover pin into the space between the fender and the strut tower. With some luck, I spotted the pin way down the cavity. 45 minutes later, a wad of duck tape placed on a stick snagged the pin and up it came. These plastic fasteners drive me nuts!
W.O.T. Stang
Jim
The part number for the battery cover fasteners.
w716510-s300
