smokescreens
My kooks came with the adapters to allow the factory cat back to remain. Im active as well but that has no bearing on anything as its just different mufflers at the back end.
Lol, I hear you! It doesn’t take long to burn through some paper when modding.Thanks NGOT8R. Looks like it's totally possible. Brenspeed also mentioned that it's possible to do. This will give me a mod to work on next year. Dumping 15k cleans out the mod fund for the year (and maybe forever according to the gf)
Those are the LTH I'm considering actually. Although I need to find out whether there is any point (from a performance perspective) to adding LTH if the rest of the exhaust system remains the same. I'm not looking to just make more noise LOLMy kooks came with the adapters to allow the factory cat back to remain. Im active as well but that has no bearing on anything as its just different mufflers at the back end.
We need a support group!Lol, I hear you! It doesn’t take long to burn through some paper When modding.
Haha! We sure do. I know I have a problem with leaving things alone, lol. It sure would be a lot less expensive if I were able to do that. Let’s just blame it on Ford for not building these cars with the best of everything on them and at least 1000 hp.We need a support group!
Support group is gofundme lol.Those are the LTH I'm considering actually. Although I need to find out whether there is any point (from a performance perspective) to adding LTH if the rest of the exhaust system remains the same. I'm not looking to just make more noise LOL
Like everyone else said, they will work.
I am not exactly sure how strong the active valves are. But don`t be surprised to see a failure with all that extra air flow at some point in time. If I had to pick one thing that would fail first on these mustangs it would be the active exhaust.
Mine failed last winter on one side. The actuator made this horrid noise every time I started the car. It sounded like a failing starter motor. It took forever to get Ford to fix it because they said "We can only fix FAILED parts. That part still works it's just failing".There was someone on here that bent their AE valves when running it in conjunction with a WOT Box.
If you go with a long tube header that is designed as a factory connect it will bolt to the factory catback no issue.So I'm going to be installing an SC on the car and everyone says "Look, if you get an SC you should get LTH as well cause... flow".
Will LTH work with the stock exhaust? I've got the Active Exhaust system on my 2021 GT Premium and I'd like to keep that as a thing cause my neighbours like it when I start the car in quiet mode while in the garage at 0700 some mornings LOL
Does anyone know if this will work or if it's even worth it?
They'd work fine!So I'm going to be installing an SC on the car and everyone says "Look, if you get an SC you should get LTH as well cause... flow".
Let me know brother can help out with some killer deals.Thanks, guys. I just ordered the catch can kit today so let me get the SC installed and all the other stuff and then I'll look at all that after from a speed shop and not the Ford dealership LOL
