Do all 1 piece driveshafts vibrate?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Two piece driveshaft equals more parts that can fail over time, ie: carrier bearings..
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
To each there own. How many 2 piece failures vs 1 piece out there ? Exactly.
Dominant1
Dr Frankenstang
No one can know that ratio, but this is what we do know. When you add decent power, your stock driveshaft isn’t engineered to handle it , the one piece is.. its the same story with the stock halfshafts. Engineered to be adequate for factory power, add power and they break.
WildHorse
N/A or GO HOME
'17 S550
No more so than u-joints on a 1-piece shaft. Good thing the mustang uses a "Jack shaft" design that uses a bolt-together yoke to mate the two halves of the driveshaft, which is often used in high-horsepower applications that will see extended punishment.
The longer the driveshaft is, without significantly increasing it's wall thickness & diameter, the weaker it becomes. Also, longer driveshafts have reduced 'critical' speeds. That's the point where it flexes and does all kinds of weird shit.
One piece shafts are easier to manufacture, which is why aftermarket companies offer them, then they use clever marketing to convince you that you need one.
I'm not saying the Mustang 2-piece is the be all end all, but put a heavy duty hanger bearing and I'll trust it more on a 1000 hp app than a 1-piece.
As for the half shafts they generally break from wheel hop. Which is usually a result of running drag radials. Stop the hop, your stockers are just fine. Up to a point.
Cheers.
crcpdx
Charlie
Cheers.
I bought a 1 piece for rotating mass. Also, and this is just my opinion, you'd think a 2 piece has more drivetrain loss than a one piece.
WildHorse
N/A or GO HOME
'17 S550
Perhaps. You do a dyno comparison ?
GregO
Illinois
S550 GTPP
He put the spacer on his lathe to check it with his gauges. It was 8000 of an inch out of true. DSS told us that this was acceptable because the driveshaft and spacer were balanced together to fix that.
.008” of runout IMO is a lot.
I’ve worked on my share of press together crankshafts (power sports) and anything more than .0015” to .002” runout the lead hammer comes out to smack into spec.
I call BS on .008” runout is OK, balanced or not.
I’m not a fan of driveshafts that use bolt on adapters.
crcpdx
Charlie
No that's why I said just my opinion. I haven't heard of anyone else seeing a difference either.
WildHorse
N/A or GO HOME
'17 S550
Figured I ask anyways. ANother advantage to the 2-piece is less stress on the trans output shaft ( supported better). Lots of Supercars use a 2-piece driveshaft.
GregO
Illinois
S550 GTPP
There is a difference.
Honestly, with the 6 speed trans the one pc. added that old school Muncie Rock Crusher feel to the car.
This isn’t about measured HP, it’s about lightning quick reaction, ditching the OEM Giubo and a lighter feel to the car.
WildHorse
N/A or GO HOME
'17 S550
No doubt there's an advantage to CF shafts. 17lb weight savings is a big one.
Dominant1
Dr Frankenstang
You can immediately feel the difference when switching to a lighter ds. Its the same as when you mount lighter wheels on your car, things spin up quicker. But over time you just get used to it. When you make big power it finds all the other parts that can’t handle it and breaks them..I have zero confidence in the stock driveshaft handling over 825 crank hp that i’m making. My one piece aluminum ds has been flawless..
https://ibb.co/YjWKhYs
No comparison.
armykyle1 [HACKED ACCOUNT
Gulf Coast
2018 GTPP premium
Guys with bad DSS drive shafts, were they aluminum? I picked up a used carbon fiber one for my 10r80 and I'm hoping it doesn't vibrate 😂
crcpdx
Charlie
Mine is carbon fiber
TheHydro
Las Vegas
2015 GT Performance Pack
I had an aluminum DSS and it vibrated a lot. I replaced it with a dynotech which is much better but still vibrates slightly around 80mph.
