RTVgav
- Mar 30, 2016
- Perth, Australia
- Gav
- 2017 Harrop Equipped Mustang
An awesome write-up Burkey. As said before, thanks for taking the time and effort to document the journey so far.
I've had a Harrop TVS kit fitted now for 7 months and have used a trusted tuner here in Perth to install (the easy part) and tune (the tricky part) using HP Tuner software. The lowdown and transition response is definitely the challenge on these setups, but with persistence it is possible to get near factory-like feel.
I found that the torque request versus throttle opening table makes a huge difference with respect to how the car feels during these transition zones. I'm by no means a tuning specialist, but I worked closely with my tuner to get a good compromise between snappy response and unexpected wheel spin in low gears.
Remember that each driving mode has it's own table of values for these - so I tuned the normal mode quite conservative (i.e. "doughy") and the sport/track mode very aggressive. Just remember not to let the unexperienced drive the car in the aggressive modes in the wet!
Lastly - do you know if there is any programming in the body module to re-calibrate the MAP/vacuum output on the centre display? My display only reads to 0mm Hg and I would like to be able to show boost as well.
