bmailpb
If you're like me and don't DD your Mustang, a battery maintainer is the best way to keep your battery in good condition between drives. Modern cars have a lot of electronics that never fully shut down and can slowly drain your battery if you don't keep a small charge on it.
The de-facto standard is the Battery Tender. However, it is upwards of $50 with the alligator clamps. Add $$ on top of that for the permanent mount kit (because if you don't get the permanent mount kit, you have to remove your battery box cover every time to attach the kit, and if you close your hood while plugged in, you run the risk of knocking the clamps off)
Enter the DIY solution:
The optimal trickle charge for a car at 12v is between 1amp and 1.5amps. What do we have here? A charger that outputs 1.3amps and has overcharge protection? Perfect - http://www.ebay.com/itm/272004329420?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
(note, I tested on my craftsman digital multi-meter and it puts out 1.27amps and does stop charging when the battery is full.)
But wait, we already said above that alligator style clips doesn't help us. Right you are. What we need is a way to permanently attach leads to the battery with a quick disconnect.
$2.18 with free shipping AND its fused for us? FANTASTIC. http://www.ebay.com/itm/401172289501?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Finally, we need a way to get the power from our charger to the quick disconnect plug. That'll run you a whopping $1.18. http://www.ebay.com/itm/391484577090?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
1. Take charger, cut off alligator clips
2. Strip back approximately 1" of wire
3. Red to Red, Black to Black with the bare end quick disconnect wires. Solder or twist together. Cover with heat shrink or electrical tape
4. Install the ring terminal connections to the battery (the nuts are 10mm for removal). Tuck the extra wire and the fuse into the battery box. Run the quick disconnect out from the battery box and allow to hang out with the grounding cable that runs through the grommet
5. Plug your charger into the quick disconnect and into the wall.
Total cost (assuming you have some heat shrink or electrical tape laying around) - $7.xx
When you are ready to go for a drive, just unplug, close the hood and take off.
