DIY 18' manifold swap into 15-17'
MarcusH
Arkansas
Oxford White 2016 Mustang gt
Is there any reason why the remote start would stop working after installing the 18 manifold
RH14GT
Fayetteville, NC
2017 Mustang GT
Posted this in the bigger forum but haven’t received a response as of yet, maybe someone on this forum will have some info.
Anyone have any information on the vaccuum plumbing for a 2017. The 15-16 models have an additional vaccuum line that runs to the rear of the intake manifold and plugs into the CAI. On the 17’s it is not there. I have the followed the diagram from lund racing on the vaccuum line layout but noticed that it is different for 2017. Any info or pics/layouts/diagrams would be appreciated.
gameovergt
Kevin
Lake Asbury, FL (Jacksonville area).
Kevin
2022 Ford Mustang GT California Special (A10)
quick ? I haven't installed mine yet (still waiting on tune from VMP). Is the evap harness extension necessary or can it be made to fit relatively easily?
blusdacolor
Leawood KS
Competition Orange 6 speed GT
I have a quick question, i'm a little confused as to where one of the vac lines goes. If someone could pm me, or text with me for like 10 minutes I would seriously appreciate it. I did lockouts and its throwing me through a loop!
Bill88stang
2016 deep impact blue premium gt 6 speed manual
I’d still like to see pics of how one is set up and what’s plug off when your run it with the runners locked
16s550
Bay area
2016 GT M6 performance pack, whipple charged
Ill get some for you guys when i get home.
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
I would really like to see some install pics of a Vortech/Paxton setup with the 2018 Manifold.
Jeff_oddo
Jeff
Mustang GT Premium
Can someone help? Does this look right for a Vortech/paxton car with no IMRC? Do i need to add the 4 port check valve? Got my boost reference by T ing the brake booster to manifold port. Thanks in advance
I’ve alwyas been told you never want to tee off the brake booster vacuum line...
MarcusH
Arkansas
Anybody figured out how to retrofit the engine cover yet to fit the 2018 manifold
16s550
Bay area
trying to upload but keeps telling photos to big -_-
SNOOPY
BEACH
2015 S550
That’s why I gave the link, pics won’t post here and I don’t know how to make them smaller. :(
gameovergt
Kevin
Kevin
anyone know what size caps & how many are needed to block off ports that are not used if locking the manifold out?
Adrianlpz93
California
2017 Mustang GT
Thought everything was working good but then I got a CEL p2006 valve is now stuck closed. The first couple of revs I can see the voltage showing the valves opening and closing. When I did a datalog to higher rpms the voltage stayed at the closed indication and never opened up again. I’m stuck on what to do next. Either I have a leak or lines routed incorrectly. Just fined it weird all was working prior to the big pulls. I went ahead and swapped the three wire pins back from side to side thinking that might be a solution since the code I believe refers to bank 1. So curious if next time I drive if it swaps sides to bank 2. Anybody have a opinion?
Same exact thing happened to me. Has anyone worked out this bug or is everyone going lockouts ?
