Duce95
Well-known member
Big Deezy
Arizona
2021 TRD Offroad
I haven’t really seen anybody do it yet so I wanted to share some photos from my install yesterday.
I made a wiring harness for my install. It’s complete plug-in play using the factory AUX switch and provided pigtails.
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3864
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3865
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3866
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3867
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3868
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3904
Kielly
Well-known member
Alberta, Canada
2024 Tacoma Sport+ 6M
Toyota really made it easy with these prewired plugs I must say. When I ordered my ditch lights I was whining like a little toddler thinking I was going to have to go through the dreaded firewall before remembering I don't have to do it at all! 😂
I don't like the placement on these prewired plugs though I must say. The one in front makes sense, for a light bar and what not, which is what I plugged my ditch lights into, AUX 2. Another one in the bonnet which would preferably make more sense for ditch lights and then they put the third inside the cabin somewhere if I'm reading the manual correctly which makes absolutely zero sense to me. I would've liked to see one near the middle or rear of the truck, for something like rollbar lights.
nicholo85
nicholo
canada
2024 tacoma
can you share which company these lights are from?
Duce95
Duce95
Well-known member
Big Deezy
Arizona
2021 TRD Offroad
These lights are Baja Designs Squadron Sport. They were used as fogs on my 2021, I took them off before I traded it in. I ordered the flat face and the mounting hardware from Baja Designs. Gave them a shine and GTG.
The wire harness I made by measuring the lengths and soldering the connections together. Protected in some loom. I will post pics of the final install once the correct replacement mounts arrive.
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3869
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3870
2024 Tacoma Ditch light install using factory AUX switch and pigtails IMG_3871
theKurt
Active member
Kurtis
Calgary, Canada
Like you said, there's supposed to be one in the cabin somewhere but I have yet to try and locate it. I *think its behind the panel to the left of the pedals. There should be one at the rear bumper too, but again, I haven't gone looking for it yet.
Tacoflvrd
Well-known member
South carolina
2024 TRD sport
Looks good. I want to add a light bar once I can get the trd pro grill. Which switch blanks are these aux plugs wired to?
bking
Well-known member
Bernie
Ohio
2021 F150
Depending on your trim and option package, you'll have 3 Aux switches to the left of the steering wheel. They're pretty obvious if you have them. I know they come on TRD Premium trims. Maybe upgrade, but I'm not sure.
Tacoflvrd
Well-known member
South carolina
2024 TRD sport
Ahhh, don’t have any aux switches but I do have the black plugs in the diagram.
bking
Well-known member
Bernie
Ohio
2021 F150
I don't know why they wouldn't put those on all trims. CaliRaised has buttons that fit those slots but you'll have to run your own wiring.
Tacoflvrd
Well-known member
South carolina
2024 TRD sport
I wonder if it’s already run and they just put in blanks. My last Tacoma was an SR and it was pre-wired for a lot of stuff that it didn’t come with. Guess I’ll have to check.
