Ecobeast305
I was going for that cord that's behind the bulb but couldn't feel the switches to pull on them
Thanks for the tip! Worked perfect!!!Okkk so it's finally done... Best way to do it its remove the bulb holder just pull the holder up and then back it comes out easy no need to fight with it!!! Then remove the cable that powers the bulb again easy just press down and pull back... Now you can finally remove the bulb with any tool you want and put the led in! To put but it simple but it can get tricky just follow the same process. And enjoy. Gotta give it to Diode Dynamics!!!! All the LEDs light up nice look awesome. I'm gonna upload some pics so you can see
Thanks Leo. Wish I would have seen this video before.
If you bridge the socket with a metal installation tool, it's going to cause the fuse to blowSo why is the fuse blowing?
When you put a screwdriver in there to pop the bulb out you arc the 2 prongs and blow the fuse. It's very easy to do since you are doing it by feel and cannot see the socket; I blew mine as well in the glovebox.So why is the fuse blowing?
