Wolfys11
Going backwards is a good practice but generally shouldnt cause any issues. Its just moreso some systems have a little slack in the timing chain, and when rotating the right way, the tension is setting everything to the correcr position, going backwards releases the tension (not talking about alot here, tensioners keep tension too) and in certain engines its possible to get enough slack for the cam/crank to get out of position with eachother. 99.9% of engines wont have interferance at such a small degree off position, once you turn it over the right way again it will go back to the original position and be fine
long story short, dont worry about it, shes fine
