Did i do this correctly? Paxton/gt350 manifold help!
Safridi22
Harrisburg, PA
Shobi
GT V8 Blue
hey folks
Can someone please tell me if my vaccum routing is done correctly? I just installed the gt350 manifold w/ imrc lockout. The car has a paxton kit on it. A member here was kind enough to send me texts of what his routing looks like and it was very helpful. However, i wasnt able to find any pics with the lockouts installed. It looked pretty self explanatory but i just wanted to see if someone could chime in and fix any mistakes i may have made.
Thanks
Safridi22
Safridi22
Harrisburg, PA
Shobi
GT V8 Blue
heres another pic. where should the brake booster go. straight into the manifold (current setup) or does it go into the driver side aspirator (where its capped off)?
Niz55
Us
17 GT350
Booster hose goes directly to the manifold.
Jay-rod427
Kansas
2016 GT C/S
Ideally the brake booster hose should go on the aspirator as one of the ports has a check valve. Keep the booster under vacuum only. OP take the aspirator and cover various ports and blow and suck through it to figure out which leg has the check valve. I can't remember exactly but can look at mine tonight.
Niz55
Us
17 GT350
Check valve is located on the actual booster so the hose goes directly to the manifold.
Safridi22
Safridi22
Harrisburg, PA
Shobi
GT V8 Blue
.Oh dayum....so the pic below is how i have it currently. I mean im obviously no expert and all my knowledge is thanks to folks like you so firstly, id like to thank yall for the replies. Im actually almost done datalogging with lund. They just need another 3rd gear pull to 7800. Ill hopefully get that done tuesday Omw back to Harrisburg from NY. Ill definately recheck the aspirator to see which port has the checkvalve. Im a lil confused at what Niz55 mentioned about the check valve being on the booster?...I mean the car is running perfectly smooth and its become an absolute animal
Hey Niz55, im sorry for the newbness but where on the brake booster is the checkvalve?
Ps....i hope that sounded right lol
Safridi22
Safridi22
Harrisburg, PA
Shobi
GT V8 Blue
Also jayrod427 whenever you can plz lmk what yours looks like.....again, much appreciated!!
Niz55
Us
17 GT350
Just follow the hose to the booster and you will see it.
