There's a difference between the 2015-2017 vs 2018+. I recall seeing threads on here about the decklids having different tabs or something on the back of the plastic.Hi all,
Do all year (2015-2022) decklids fit all S550s? Or is there slight issues that can be modified to work. Thanks in advance my S550 gurus!!
Anthony
Hi Cobrajet,There's a difference between the 2015-2017 vs 2018+. I recall seeing threads on here about the decklids having different tabs or something on the back of the plastic.
Dimensions and curvature of the factory decklid panels are the same between years.
Doesn't stop from swapping or interchanging, just slows the swap process due to having to modify the back of the panel to fit the trunk lid.
I was searching after my last post to give you a link - came across this one for your reference, it shouid help with the minor mod needed with the tabs:Hi Cobrajet,
Thanks for reply, appreciate it!!! Ohhhhhh ok, Got it!!! It needs to be modded, maybe remove some additional tabs? Just as long as size and curves are same, Im golden. I can always dremel whatever needs to be removed.
Thanks Anthony
Thank you soooooo much!!!!I was searching after my last post to give you a link - came across this one for your reference, it shouid help with the minor mod needed with the tabs:
https://www.mustang6g.com/forums/threads/2017-decklid-interchangeable-on-2019.134732/
