Aaron_ATX
Been using the ford procal tune for over a year now with no other mods besides a mishi. intercooler. Recently the procal software was updated to allow for some dataloging, and after looking at mine I need something to compare it to.
93 octane being the only real constant I am interested in.
Stock tune, ford tune, whatever tune, what kind of max boost are you seeing and how much total timing to you expect?
On one pull tonight from a dead stop (60f outside temp) I am already getting 24-25 psi in second gear (top of second) and by 6k rpm total timing has dropped to 4 to 5 degrees advanced.
top of 3rd gear I am around 26 psi with only 1 - 3 degrees of timing left by 6300 rpm, (between shifts boost spikes to 30 yikes)
and partway thru 4th (let off at 5300 rpm) 26 psi and 1-2 degrees or even less of timing is all I am seeing.
This seems a little excessive for what the ford tune is designed to do. I am wondering if I am having a wastegate issue causing more boost which in turn is causing excessive amounts of timing to be pulled.
According to my data log the knock correction is ALWAYS at -1.0 with no movement ever. There is a switch in the ford tune to turn it on, meaning that it will allow for adjustments. It is currently off as was recommended by ford, and it appears that no adjustments are being made.
My concern is that all this boost and all that timing being pulled is hurting my overall power output. Not to mention 25-26 psi under load being questionable for a bone stock motor. And isn't the stock turbo a wee bit out of its efficiency range at those boost levels?
Anyone care to share some of the data they are seeing with basically a stock longblock and turbo, with tune or without?
