09cs
That looks pretty spot on! Would you say like 99% close? Any issues with it getting hot in the sun?
It’s a 99% match along with the magnetic accents. I’m sure it will get hot when summer get here. My car stays mostly garaged at work and home. They sell “beanie covers” for them. I have a small suede rag for sunglasses that could be used to throw on top if parked in the sun on a hot day.That looks pretty spot on! Would you say like 99% close? Any issues with it getting hot in the sun?
AnyIt’s a 99% match along with the magnetic accents. I’m sure it will get hot when summer get here. My car stays mostly garaged at work and home. They sell “beanie covers” for them. I have a small suede rag for sunglasses that could be used to throw on top if parked in the sun on a hot day.
any more info on your install experience?It’s a 99% match along with the magnetic accents. I’m sure it will get hot when summer get here. My car stays mostly garaged at work and home. They sell “beanie covers” for them. I have a small suede rag for sunglasses that could be used to throw on top if parked in the sun on a hot day.
I haven't noticed my white knob getting uncomfortably hot, ever. I do garage the car and I don't drive it to work and leave it out in the parking lot all day. But I've had it out on hot days and it hasn't been a problem. The track day I went to last year was triple digit heat, but of course I had the windows down all day.Any issues with it getting hot in the sun?
The install is easy. Removing the OEM knob is a PITA. I was afraid to put a heat gun in my car, a blow dryer for 10 minutes helped break down the locktite. I used a strap wrench and a microfiber towel but still had a little damage. Also used a washer to get the alignment correct on the install. I learned all of this on this thread where a few people talk about setting the hight.Any
Using a washer instead of the lock nut allowed for the knob to set a little lower.The install is easy. Removing the OEM knob is a PITA. I was afraid to put a heat gun in my car, a blow dryer for 10 minutes helped break down the locktite. I used a strap wrench and a microfiber towel but still had a little damage. Also used a washer to get the alignment correct on the install. I learned all of this on this thread where a few people talk about setting the hight.
Did you paint this yourself or order it in Orange? Looks Great!That looks pretty spot on! Would you say like 99% close? Any issues with it getting hot in the sun?
Good to know. I may just use loctite to get it low. Had to use adapter? Do you have a link to the washer trick?Using a washer instead of the lock nut allowed for the knob to set a little lower.
Not mine, but he ordered it orangeDid you paint this yourself or order it in Orange? Looks Great!
Where can I get more info on this?Using a washer instead of the lock nut allowed for the knob to set a little lower.
You just find a washer that will fit (stopping where the threads stop) and screw the knob all the way down. If it's perfect then you're set. It won't be though, so you'll need to remove everything, sand the washer, and repeat until you fine-tune the knob's position all the way down.Where can I get more info on this?
Wouldn’t it be much easier to just use loctite ?You just find a washer that will fit (stopping where the threads stop) and screw the knob all the way down. If it's perfect then you're set. It won't be though, so you'll need to remove everything, sand the washer, and repeat until you fine-tune the knob's position all the way down.
You could also use a thin nut as a jam nut with your threaded insert:
https://www.fastenal.com/product?query=11508476
Go ahead. Just be aware that the thread adapter that comes with the Billetworkz knob is very small and it won't be easy to get off. I don't recall if there are even flats on it.Wouldn’t it be much easier to just use loctite ?
