Did you ever try removing that cup holder trim? Wondering if it can be removed myself.The shiny chrome bezels around the cupholders and transmission shifter (auto) are a shiny chrome. I'm thinking of removing these and maybe spraying them matte black. Are they easily removed? Thanks.
Is there a way to add some sound insulation under there? Too much transmission noise is being transmitted through there.The trim ring is rather easy to remove; I've pulled and wrapped mine. It's just some Torx screws holding it in to the trans cover.
I also lined the underside of the trans cover with heat-reflective foil, which cut down on the heat intrusion into the cabin.
The trans cover itself is pretty easy to remove. Just don't yank on it too hard from the rear until you release the key detector plug below the cup holders.
