Crank case breather vs catch can breather.
Ptrug
Phil
2019 Mustang GT Premium PP Convertible with FI
What’s the difference and benefits between a crank case breather (oil cap style), and a catch can breather and do I need both?
19 GT ESS supercharger at 700hp.
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
Boosted, I’d recommend a dual catch can setup. When you say catch can breather, are you talking closed loop or vent to atmosphere? I would always get a little oil misting with a breather venting to atmosphere.
SheepDog
Colorado
Iconic Silver 2022 MACH 1 HP
The valve cover and oil fill breathers will eventually piss oil vapor all over your engine bay, the catch can with a breather will not.
MarquanTR
Delaware
Marquan
2021 Mach 1
I have the crank case breather and the vented catch can from UPR, Although I’m not boosted yet. I also have the hi flow PVC valve
Ptrug
Ptrug
Phil
Yes. This my issue. Oil leaking on the engine. I wanted to know if having both breathers had more value then just one. While its all in a closed vacuum system, does the crank case breather offer more protection being right there in on the crankcase rather than allowing pressure to run through the hoses before it gets vented?
Ptrug
Ptrug
Phil
I have catch can on both driver and passenger since but they dont vent to atmosphere. I was wondering if there is a benefit to getting a venting catch can along with the crank case breather or is there no benefit?
junits15
MA
Justin
2019 Mustang GT
I assume you're looking at the CCM breather? They work but what happens is that dry filter material eventually soaks with oil and then starts spraying it everywhere.
If its a race car its a great solution because it will vent the gasses really easily, for a street driven car it will make your engine bay disguising really quickly.
Proshop
Billy
2021 Ford Mustang GT
I ran a UPR VTA CC and the oil cap breather and never had an issue with oil in the engine bay. It also helped release any excess pressure built up since I was pushing around 18 psi with my ESS kit.
SheepDog
Colorado
In my opinion, when forced induction, you should have both valve covers plumbed to a catch can (either a single vented can with dual inputs, or a can for each valve cover) and the PCV valve replaced with a high flow port. Then, the port in the intake manifold and the port on the Air intake should be capped. This way, you have 0% shmeg going back into the engine.
PCV systems were primarily designed to recycle the crank case vapors/pressure back into the intake so that the fuel and oil was not being released into the atmosphere. Good for the environment, not so good for the engine.
When you are dealing with boost, the most critical time to relieve the crank case pressure is during boost, when the throttle is wide open. The blow by pressure from the Supercharger/turbo goes into the crank case, in addition to the pressure generated by the pistons thrashing up and down at high speed. This pressure needs a way to escape the engine, so by having free flowing ports to a catch can, all the pressure is relieved at the most critical moment.
The OEM PCV system only relieves crank case pressure during low engine speed/throttle closed events, because the system relies on intake manifold vaccum to suck the vapors/pressure out of the bottom end. This is fine for when you are just cruising down the highway, but does nothing to manage the pressure during boost when you need it most.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
I have both the UPR crank case breather and a Vented catch can on mine. Doesn't hurt to have both
Ptrug
Ptrug
Phil
Very insightful. Thank you.
Does having the crank case breather negate the need for the catch can breather? I understand it can't hurt to have both but is there a true benefit to having both or one over the other?
SheepDog
Colorado
When not using the PCV system as the manufacturer intended, you want as much relief as possible. Ford didn't design these cars to have forced induction.
When running a non PCV system, you want the port and lines to the catch can as large as possible. The PCV valve in this scenario is just a restriction. UPR makes a replacement that gets rid of the valve with a wide open 5/8" port. Having the oil fill breather filter is great, as long as it isn't getting saturated, which will eventually make a mess. It really depends on how much boost you have. 10 PSI probably wont make a mess as long as the valve cover breathers are flowing properly. Crank it up to 18-20 PSI, and your gonna have a mess on your hands
Silver Bullitt
Parkville, MO
2018 GT Coupe PP2
If you have a can on both sides, you should be good. Like I said, I never had much luck running a breather as it will eventually start misting oil.
Ptrug
Ptrug
Phil
Thanks. I will get a catch can breather. Right now I have the ford performance oil separator on the passenger side and the J&L on driver side. Driver side is always bone dry but not passenger.
I am not sure exactly how much boost I have. A vacuum gauge is on the to do list. I can say that setup from manufacturer says 8psi (ESS G2 - 6PK 120mm (8PSI), Intercooler Size:G3 spec (40% larger)) and the crankcase breather frequently spits oil. I feel she is def more then 8psi... She is beast. I have had the supercharger on for about a year now.
Ptrug
Ptrug
Phil
Even the catch can? I am more interested in saving my engine and seals then oil stains.
My crankcase breather spits a lot of oil. I put a paper towel over it with rubber bands to catch the spit and replace it every once and awhile. I take if off if i ever go anywhere i'm going to show it etc...
