Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2022 F150 PowerBoost
- Vehicle Showcase
- 2
Hi Rob, initially I did not because I did the install on my two post lift. I "eyeballed" the camber front and rear when it was up in the air. As mentioned I installed Steeda's rear camber arm and adj toe links. When I was all set and done and the car hit the ground and after a test drive I put the car on my four post lift and clocked the front. I loosened up the front bushing bolt (most forward arm) and bearing bolt (rearmost front arm) and then aired up to 125psi squared then back down to ride height and re-tourqued them. I watched them as it raised and lowered and without a doubt it clocked itself. When I was done I could plainly see the front toe had changed quite a bit. I did not have to do the back because I have changed out all the bushings for bearings.[MENTION=8761]Jmeo[/MENTION] and [MENTION=20909]d4rk_hrs[/MENTION] did you have to reset any of the suspension items(like LCAs) prior to alignment or during install? I've only seen one video that says to do it but the major company install videos didn't mention it or show it.
I would suggest clocking the bushings before an alignment not after as things definitely change during this and you do not want to get another alignment.
I must say being able to raise the car to get on my lifts without having to drive onto ramps of wood is a huge convenience
4x4 mode :lol:
