olaosunt
Here goes …
Alfonzo Novello built 5.2 - Gen 2 voodoo block /Mahle 12:1 pistons /Manley rods /boss crank /Gen 3 heads /livernois springs / Predator head gaskets /ARP head studs .
Motor had about 3K miles since built
Whipple rails and ID 1300’s
Dressed with 10 rib Gen 5 whipple brackets/20%ATI damper /MFP crank support /
Gen 5 whipple with 10 rib pulleys(x6 from 3.75 down to 2.75) . Upgraded heat exchanger with fans .
UPR catch can
Richardson built 10r80 with extra steels clutches in E&F .
Will come with engine harness.
Gen3 ECU /N gauge with multiple tunes for above combo
Fuel system with DWx2 hat with DW400 pumps . will need some lines - will get what’s needed
$30K but VERY open to offers
Gen 3 /10r80 control pack available if buyer wants for a swap - $2300
if no takers by the time my Fox body chassis is done then it’s going in . I already have a Fox swap with Edelbrok so was wanting to go TT with this chassis preferably.
Kooks 1 7/8 headers /cat delete and green cats - interchangeable with resonated mid pipe and active exhaust available for S550. -$2500
QA1 CF drive shaft also available for S550- $1300
PP radiator also available- make an offer
S550 custom gauge cluster with mount for N gauge /E85 -make offer
S550 custom gauges with boost /oil temp /pressure /fuel pressure - make offer.
I know it’s a lot of $$ but the whipple set up alone with 1D1300 was about $15 when I added it to a cart on Lethals website .
Engine build is about $13-15k
Trans rebuild is about $3500
Drop in your car and save your power train for if you ever want to trade your car and return to stock or build as “spare “ like I did .
Also have other options including brand new 5.2 SB’s/heads/timing /parts to build brand new Gen 2/ 3 long blocks /built 6r80’s/control packs if anyone is looking to do swaps .
PM for details
Prefer to sell as package(or smaller packages if needed )
Some pics are from before engine was installed last year .
everything is pulled and last pic has name and date .
Thanks for looking .
UPR catch can
PM for details
