Come on Ford...really? Oil filter drain tricks?
ctandc72
VA
'19 GT 6 speed Base
Did the first oil change on the '17 3.7 last night. Did the engine design people never talk to any of the other engineers? The oil filter is placed so that when it's loosened, it drips oil right onto the wiring going to what I'm assuming is the electronic steering control.
Cleaned it all up sure - but someone has to have dealt with this? Foil? What? Anyone got a trick that keeps the oil off the wiring / rack and pinion?
Nagare
Ft Lauderdale
2017 Lightning Blue V6
Now this is just speaking off the top because for mine I was already dropping her off for something else, but could you position a hosed funnel in there or no? Might need a wide neck to not bottleneck at all though.
gov cheese
darksideofthemoon
2016 3.7 051A Guard
I let the dealership change my cars oil one time, never again. They used a shorter filter than the fl-500s and god knows what oil to save money.
Back to doing my own oil changes, 30 minutes on the ramps in the driveway done.
I have a form-a-funnel. i bent it into a shape that wedges into the frame and pushes back against the block to hold it in place.
1. loosen the filter from below
2. wedge funnel under filter
3. finish removing filter from above
https://www.amazon.com/FORM-FUNNEL-Flexible-Draining-Tool/dp/B017MTFIYE
HISSMAN
Large Member
West Virginia
I have one too. They should come with the car in a nice tidy package located in the glove-box. The 5.0 is in no way any better located than the 3.7.
ctandc72
VA
'19 GT 6 speed Base
Much appreciated. Now in my Amazon list. Figured someone else have to have dealt with this, no need to reinvent the wheel.
six_shooter
Joe
2015 Mustang V6 DIB, 2018 HD Iron 1200
Thanks for the form a funnel tip. I've just been covering everything with grocery bags so far.
dgc333
MA
15 Mustang Ecoboost Premium
A free solution is to take an empty windshield washer fluid bottle and cut it up to fit around the filter.
ctandc72
VA
'19 GT 6 speed Base
That's not a bad idea either. I'm sure I have one sitting in the garage.
Rick#7
Hudson FL
2015 GT 50 Years Appearance Package
I just use a small ordinary funnel, about 3" diameter. I position it under the filter with the spout poking through the wiring to hold it in place, then stick a piece of 1/2" fuel line on the tip so it will drain into my oil drip pan.
TURTL3
SoMD-DMV
2016 LB Mustang 3.7 6MT
I was planning to take one of those ziplock freezer bags and put it around the filter. Doing the first change next weekend.
DANA44
Central Connecticut
2016 v6 convertible
I just lay a rag over the e! electrical and spin off from the top
It comes off so quick not much is spilled
V6junkie
Va
2015 v6 ingot silver
I usually just find a fast food cup and cut to size and place under the seal and loosen the filter letting drain into the cup and remove the filter catches 98%of the oil
wildcatgoal
@sirboom_photography
TBD
1) Poke hole in filter with a screw driver - just takes a couple light taps. Drain.
2) Aluminum foil
3) Smile at how clean of an oil change you just did...
DR_
In a van down by the river
David
like a complete jerk
deja vu
Thought the message from the Dearborn employee was telling.
Steering and powertrain are separate groups here. This was probably the result of using a steering setup that's similar to existing cars and plopping it into a platform with a north-south engine. It's little stuff like this that can slip through the cracks of vehicle integration.
Reap
AL
Harald
1999 Mustang 2017 Mustang
I just unfold the oil filter box and position it to deflect the oil away from the wires.
