cobo10201
- Jun 2, 2019
- Houston, TX
- Coby
- 2017 Ford Mustang V6
So I’ve actually been looking into this and talked to two local performance shops. They both told me too much backpressure after the turbo would actually LIMIT building boost because the turbine would take longer to spool up. Without getting to science-y, the turbo needs high pressure from the engine (pre-turbo) and less pressure after the turbo. The lower the backpressure after the turbo, the faster it will spool. Higher backpressure from the cats would cause it to spool slower and build less boost. They basically told me modern cats are extremely efficient and shouldn’t be causing any over-boost issues with the turbo. If anything removing the cats or getting high flow cats would increase the ability to make boost.I'll keep going back to the question of CATS and restrictive exhaust. If so, the backpressure is killing those turbos.
The main thing each one told me is unless I’m really going for max performance with track-only goals, there’s no reason to remove or replace the cats. The F-150 comes with essentially identical cats from factory and the turbos are build for that setup. One of the shops actually put my car on a lift to check everything out and they said the only thing my cats are doing is making me build boost a little slower and the current setup shouldn’t be dangerous to the turbos or the engine.
Truth-be-told I think at least one of the turbos has been bad from the start. The driver’s side turbo has always made a slight chirping sound when spooling, and it’s not a normal turbo whine. I’m thinking the combination of the overboosting issues and pushing the damaged turbos with WOT and 0-60 pulls just put them over the edge.
