Well midrange is 6 to 7k rpm. Close gearing and high rpm really change what's the middle of the powerband. It should be rare on a track that you go as low as 5k.That's surprising, it's the opposite on the 5.0.
I'm rev'ing out to 8 now, 9 shorty. I went CJ, since the 350 just can't flow on the same level at that high of a RPM. The throttle body alone is a huge difference. Every graph I've seen to date has the 350 tapering out past 7,500 on a smaller displacement engine than yours.Well midrange is 6 to 7k rpm. Close gearing and high rpm really change what's the middle of the powerband. It should be rare on a track that you go as low as 5k.
The other site has a full article on everything you need to know. Google cobra jet manifold gt350.I'm rev'ing out to 8 now, 9 shorty. I went CJ, since the 350 just can't flow on the same level at that high of a RPM. The throttle body alone is a huge difference. Every graph I've seen to date has the 350 tapering out past 7,500 on a smaller displacement engine than yours.
Can you link me to the tests you're speaking of? I'm curious to see what injectors and throttle body they are using. Also, are they running factory exhaust manifolds?
Boss motor didn't quite meet ford's requirements for longevity at 8KHow is a Coyote not letting go at 8k, let alone 9?
Gt350 mani is a great all around mani.. There is a reason why VMP went back and kept the gt350 mani vs the CJ. The stock gt350 2.75" exhuast does flow a lot more that the stock GT exhaust.Found the reason for the drop off....
The car retains stock exhaust. If you can't get the air out fast enough, it doesn't matter what you can put in. So, that brings me back to the original point. This engine with full exhaust, E85, and supporting mods would immensely benefit from a CJ. It should fit with drop mounts and the strut bar removed. 530-550 RWHP would probably be within the realm of possibility without opening the engine. I would at least do CG and OPG before turning the redline up much more.
