CrashOverride
- Aug 18, 2018
- Under a hood
- 2015 Mustang GT
Hey all, it's been a long time since I've been on here, but fret not as I still have my Mustang. Part of the reason I've been offline so long is my new project.
I'm doing a resto/rusto-mod 1954 Ford F100. I'm quite a ways away from being done, but I like to have a plan in place many steps ahead to source parts and so forth.
In short, I really like Sync3 (I also have it in my 2017 F150) and I'm a firm believer in a radio having two real dials, so the easy solution of throwing in an aftermarket touchscreen just isn't an option I'm willing to do.
So what I'm trying to do is get Sync3 working. I do not care about getting the reverse camera working. I'd like to be able to still "talk to it" using ForScan. I have the FSM, so I have the various pinouts, but my knowledge of the CAN bus is only theory based and not a practical application.
From what I've been able to find, there are multiple CAN busses (Low, Medium and High Speed) and I seem to remember the bus is sent over a twisted pair wiring, at least for the medium and high speed runs. I had planned on using twisted pair ethernet cables as I don't have a sync3 wiring harness I could use (Of course I could hit up any LKQ pick a part if need be). I know there is the APIM, ACM and FCIM. I seem to remember the busses need to be terminated at the ends with (I believe a 50-ohm resistor).
I guess the main question is this - if I chain the modules together using the twisted pair, and also attach a OBD2 port with the data pins, will it work? I don't know if there are other modules that would need to be there, like a BCM or some sort of central computer/gateway to manage the different CAN busses and/or translate the different busses so that they can talk on the OBD2 connector. From what I've read, the CAN bus is a mesh/point-to-point setup, which to me means every device is "smart enough" to work without a main controller.
I have done some searches and I haven't found anyone that has done this, anytime you use the word "retrofit" you get people going from sync2 to sync3, so I'm not finding anything to answer my questions. I've searched for "building a bench harness", but I haven't found anything related to firing up a sync system on a bench. I'm not knowledgeable in SCADA systems, so I don't have background knowledge there to answer this question. I'm not an EE either, I'm just a curious creature
Of course I could just buy the equipment and try it out, but that's a decent amount of money to spend to test a theory.
Thanks for any of your thoughts!
