69mach1-395
- Dec 4, 2014
- central nm, usa
- 2016 RR GT/CS
- PM me for my mailing address...For anyone trying to get the front emblem off:
- Take the hood latch off and set it to the side, it makes the hole large enough to get your arm through without causing damage to your arm.
- Look at the pic of the backside of the emblem and get an idea of where the nuts are.
- Using a flashlight, you can see at least the bottom nut and the side one as well. Might want to stick your hand and feel around first.
- Use a 13mm socket, wrench isn't needed. Reach in with the socket and use it to take off the so called nuts. They aren't tight and are cheap aluminum. A couple of mine actually ripped while I was removing them.
- Shouldn't take more than 10 minutes.Don't forget to replace the hood latch.
