Bushing replacement cost?
JungleG1337
MD
2015 Ecoboost
Hi everyone,
I am stuck at a crossroad. After I have BMR lockout kit, Airlift, and Vertical Links installed. The rear has produced a lot of squeaks when the frame is flexing or over bumps after a year of driving. I suspect OEM bushings are giving out.
I tried to lube the vertical links and spray down other components like everyone suggest but no dice.
I am thinking to put the stock vertical links and remove the lockout kit. I think the lockout kit both have cross-thread on the driverside. If IDK if it is a good idea to remove that lol.
Have anyone went back to stock after upgrade their suspension? I keep telling my self, it is a race car and race car makes noise.:headbonk:
Rebellion
Houston
2016 Competition Orange GT
I don't believe it's the CB005, it ain't even a moving part (per se). Mine wasn't bolted well for a month or so...didn't feel anything. Only found out when someone looked and said "why is that bolt backed out?"
I would inspect all of the bushings/bearings (knuckle, camber arm, toe arm, lca, vert link, etc.) including the shock attachment points.
JungleG1337
JungleG1337
MD
2015 Ecoboost
I went through a few times and still yet to figure out which one of the bushing is making noise. Now that weather is cold, Im gonna have to ride this out. It would be amazing if BMR or Steeda have a complete poly replacement to every bushing
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Steeda does have a wide variety of urethane and squeak free solutions.
Reach out to Mike D @ 954-960-0774.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Hi everyone,
Have you called us to discuss? Typically these occurrences are super simple to resolve. :cheers:
z06psi
Evans, GA.
Andrew
The pot stirrer
BMR Tech
Tampa, FL
Dion
I have spoken to the OP.
I suggested he start by replacing the current links with the stockers, and if that does the trick I will rebuild his links to update them to the current design, or offered him a deal on our Poly Links (TCA048)
JungleG1337
JungleG1337
MD
2015 Ecoboost
Thank you for the great customer service. Ill update you once I swap out the vertical links when the weather permits.
JungleG1337
JungleG1337
MD
2015 Ecoboost
[MENTION=9985]BMR Tech[/MENTION] [MENTION=25806]SteedaTech[/MENTION]. The noise squeak was from the Vertical Links. I inspected all bushings and they showed no sign of wear or cracks. Shocks are still good. After, the test drive. I can hear a slight creak and crack when weight is transfer from left to right or right to left and I turn the corner at random times. Could this be Sway bar or Sway bar links?
SteedaTech
Pompano Beach, FL
2016 Mustang Q750
Yes, I would check the sway bar pivot bushings and end links to make sure they are torqued properly.
Lube the Sway Bar pivot bushings with synthetic Super Lube, which available at any good hardware store.
Steeda Tech
JungleG1337
JungleG1337
MD
2015 Ecoboost
Steeda Tech
sway bar end links are tight. I will take lose up the sway bar and lube the bushing with Super Lube Synthetic like you suggested.
