Cheaper plus you don't have to go through the shit show of installing headersIf you get bigger injectors and pully down to run more boost you will get a bigger performance gain than getting headers and will cost less.
Are you gen 3? Get dw95s. That will set you up nicely. Also you do know more rpms on a centrifugal sc = more boost so be careful with the rpms.Ordered a pulley a few hours ago (4.10=9-10bs, from the 6.5 I’m at now).Now, what kind of injectors should I be looking to get?
18+ cars are gen32019 Bullitt Gen 3 right? What do you mean be careful? Could I hurt something? Pro Charger told me double digits around 12 is inm
you need to start modding some other things to the engine
Man this is a lot...........I didn't want to go to e85, but if I'm understanding you correctly; I need to if I increase the boost to 8.5-9lbs, with bigger injectors?18+ cars are gen3
You need e85 if you wanna go higher on boost. That's what they mean or told you. The way centris make boost is linear. More RPM = more boost so for instance of you decide to rev to 8k RPM you will make more boost than if you rev to 7k RPM
Many tuners will not tune you on small injectors. Who is you're tuner? You can run gas on any injector, when you run out of octane at a specific boost level you need race gas or e85 afterMan this is a lot...........I didn't want to go to e85, but if I'm understanding you correctly; I need to if I increase the boost to 8.5-9lbs, with bigger injectors?
Who is your tuner? Have you talked with them? Tell your tuner your goals and what you want to do and they should be able to tell you exactly what to buy or what you need.Man this is a lot...........I didn't want to go to e85, but if I'm understanding you correctly; I need to if I increase the boost to 8.5-9lbs, with bigger injectors?
Ahhh makes senseI dont think he has a tuner yet. I think he's on a procharger tune.
Yes, I have a tuner. It had to be tuned after installing that apparatus.Ahhh makes sense
Golgo is gonna need a tuner anyways lol, imo more important than thinking about which injectors/pulley to buy
