budget drag wheel and tire setup, check this out.
Discussion in 'Dragstrip and Launching' started by Stanced, Feb 1, 2018.
  1. Chuckles the 3rd
    Chuckles the 3rd Well-Known Member
    First Name:
    Chuck
    Vehicle(s):
    2018 Ford Mustang GT
    Aug 18, 2018
    Occupation:
    Elevator Mechanic Apprentice
    0   0   0
    I just purchased 2 of the silver MR136’s for $72.xx each! Motegi says they’re 23ish pounds. Time for some 275/40 17 R’s (stock tune) and see if I can break into the 11’s A33D5CA5-D88C-4B58-AA33-E8DC3685177A.png
    mustangv6magn and OU81 like this.
  2. Stymee
    Stymee Well-Known Member
    First Name:
    Joel
    Vehicle(s):
    2019 Mustang GT
    Mar 19, 2019
    Philadelphia, Pa.
    1,300
    424
    0   0   0
    Do they make them in all black
  3. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    I believe they used to, but I no longer see any 17” MR136’s in black.
  4. Black Stang
    Black Stang Well-Known Member
    First Name:
    Mark
    Vehicle(s):
    2019 Mustang GT
    Jan 12, 2019
    North Louisiana
    46
    #94 Black Stang, Sep 6, 2019
    You got a part number ?...I guess the 44mm offsets are for the rear I only want a pair for the rear for some 275 40 17 mickeys
  5. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    Yessir I believe the 45mm offset would be too much for the front. D07FCBD7-6F9F-48F3-B87B-EF2582A6B321.png
  6. Black Stang
    First Name:
    Mark
    Vehicle(s):
    2019 Mustang GT
    Jan 12, 2019
    North Louisiana
    46
    Thx...i wish i could find some black ones...are you running these on your car ?
  7. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    I just got them yesterday, and plan to put a 275 40 17 radial on them while I’m on a stock tune. No pics on the car yet
  8. Black Stang
    First Name:
    Mark
    Vehicle(s):
    2019 Mustang GT
    Jan 12, 2019
    North Louisiana
    46
    Col
    l be sure to post some pics...cant beat the price. Leaving mine stock too...dont plan on doing anything to void the warranty.Waiting on the ford PP
  9. mustangv6magn
    mustangv6magn Well-Known Member
    First Name:
    @mmagnetic2016
    Vehicle(s):
    2016 procharged v6 magnetic 2016 ford eplorer
    Mar 5, 2016
    328
    36
    Rating:
    100%
    1   0   0
    52DBE01C-E54F-4A70-9132-13B69FDE0DE0.jpeg Just ordered these
    Chuckles the 3rd likes this.
  10. Thatguy
    Thatguy Well-Known Member
    Vehicle(s):
    2018 Lightning Blue Convertible with Premium Package
    Jan 29, 2019
    Massachusetts
    174
    52
    0   0   0
    It's time for me to order times. Still going back and forth between 275/40 and 305/45/17s. You don't think there will be any loss with the taller tire? They are closer to the stock size than the 275s. Those are much shorter (more gear).
  11. msweet
    msweet Well-Known Member
    First Name:
    Vehicle(s):
    2019 Ruby GT PP 10A w/ Magride, Recaros
    Nov 3, 2015
    Sydney
    1,632
    1,515
    Rating:
    100%
    1   0   0
    Hard for me to say without testing both. With the weight drop and gearing advantage the 275s certainly feel more lively by the butt dyno, I went with them to drop my 60'.
    Unfortunately last time out I only did 3 runs, first was shit and I spun a lot on the other two (through 1-2 and 2-3 shifts). Still ran 11.55 both runs, with a best of 123.83mph, up from 123.10 with stock wheels and 305/35 MTs.
    Waiting on a new axle, then I will figure out the right pressures/heat and get these hooking. There's definitely a lower 11 in it if I can get it right.
  12. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    I went 275’s because that should have me around 7000+ rpms throughly the traps in 6th.
  13. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    Just test fitting the MR136 wheels and the high points on the brake calipers run the inner barrel of the wheel. It will need a 1/16” five or take to clear.
    mustangv6magn and Thatguy like this.
  14. Thatguy
    Vehicle(s):
    Jan 29, 2019
    Massachusetts
    174
    52
    0   0   0
    I spent a few hours reading drag wheel/tire threads today. Some people say the 99-04 17x9.5 wheels will fit and others say they rub. I've been looking at those years first because a lot of the wheels are inexpensive. My calipers are painted so I really don't want to grind them down then paint them again. There are some inexpensive wheels listed for the S550 so I might go with one of them.
    As for tires, I'll probably decide when I order. I'd say at least 85-90% of people who have posted in different threads went with 305s. I did some quick math. The 26.1" tires are 5% shorter than stock (27.3") so my 3:31 gears would be about a 3:50 ratio. 305s are 2% taller (they look taller than that). That would cut the gear down to about 3:24. I don't get into full boost until about 3500 RPMs so I think either size will work fine. Most of my 60' times on street tires have been in the 1.90-2.00 range. There have been a couple high 1.80s but nothing consistent. I'd hope to shave a couple tenths off with a better 60'. I'm also going to put the stock 18s back on the front for the track. Will save some weight and rolling resistance. One other upgrade is the car will be running on E30 so I'd like to turn my recent best of 12.69 into a low 12.
    mustangv6magn likes this.
  15. Chuckles the 3rd
    First Name:
    Chuck
    Vehicle(s):
    Aug 18, 2018
    Occupation:
    0   0   0
    I dremeled the rear calipers over the weekend to clear the MR136’s. I ended up taking off about 3/32” on the high points of the caliper in line with the hub face axis. I spun the wheels with the car in the air and it clears. It’s tight but there’s daylight. Next up is to paint the calipers race red to match the car.
Loading...
Share This Page
