Broken Half Shafts With An Automatic?
Cardude99
Phoenix, AZ
Sam
2018 Ecoboost
Sorry not to hijack but can you break a half shaft on a manual if you just use street tires?
Tonyrhmartino
Fort Wayne, IN
2015 KB GT
What I have seen is sticky tires and launching. But anything is possible with power adders. Keep searching the threads.
MikeD1
Central FL
2016 Challenger Hellcat
I asked my installing dealer & Roush about this and they both said the stock shafts should be OK with street tires. They said the autos "load" the drive line so there is not that initial shock to everything dropping the clutch in a stick causes.
IF you intend to put on wider tires, drag/sticky radials, take it to the strip on a regular basis, want to be the neighborhood burnout king etc. then it's time to consider upgrading.
As with anything mechanical, they could break on a hard launch from a stop sign if there was some weakness in them from the plant etc.
My dealer said they knew a lot of the guys with autos they built were going to the strip at least on occasion & they had not seen any come back for 1/2 shaft issues (yet).
yellowstangatl
Minnesota
2024 Dark Horse Premium
I've heard of a 900 hp helion car breaking a half shaft.
Sent from my SM-G928P using Tapatalk
GTBOB
Fairfield Township, OHIO
Bob
'18 GT, Royal Crimson, 10 speed, Active Exhaust
With a manual car, wheel hop is the destroyer of the stock axles regardless of what tires you use. If you experience wheel hop, get out of it quickly.
