Brakes - Unintended Acceleration!
Lakeland-GT
between IN & FL
SErik
2015 Mustang GT PP Race Red
1,001 miles: "brake fluid low" warning lights comes on.
Dealer says master brake cylinder is leaking into brake booster.
Both replaced under warranty.
2 days after repair: "Hill start assistant not available" warning light comes on randomly; (wonderful, I can't wait to hear the dealer say he can't replicate the issue)
AND
the cruise control (when turned on) does NOT turn off when depressing the brake pedal; super dangerous as it causes unintended acceleration. You mash the brakes, but the car rockets on at the cruise control's set speed.
Thankfully the cruise control does turn off when dumping the clutch. Lucky for Ford I have a manual trans. otherwise there might have been an accident.
Sure you can also turn off the cruise control by hitting the off button, but in an emergency when all of a sudden your brakes don't work and the car is accelerating finding the little off button is the last thing you'll be doing.
Both of these new issues are most likely related to the previous day's brake repair.
Anyone know what specifially causes either of these problems?
Going back to dealer tomorrow.
RetroSkippy
16 Ruby GT PP
I've never looked at one in a Stang but it sounds like an issue with the brake switch. Might want to see if there is an adjustment and check if your lights are working when you hit the brakes.
Lakeland-GT
between IN & FL
SErik
That's exactly what the dealer said it was, brake switch, replaced under warranty, one of its wires wasn't making contact in the harness and caused both problems.
Brake lights worked before and after though.
