- Mar 13, 2016
- Titusville, Florida
- Website
- www.facebook.com
- Tommy
- '15 GT PP
Charlie,Morning folks,
I’ve recently gotten into a bit of tracking my non-PP 2021 GT. So far just have done a few laps at VIR and a trackcross at summit point.
i am tracking that I need to get some higher temp pads and fluids before a HPDE track day. Any advice on good pads for this plus daily driving? I know it’s a compromise.
so far I’m looking at EBC Bluestuff or Dynamic Friction Active Perf - low metallic. The DF ones are far cheaper.
I would greatly appreciate any experience or anecdotes on this subject. Thanks!
What are your true goals here? Everyone pretty much gave you the correct advice on G-LOC pads. The issue is heavy fast Mustangs and semi-adequate brakes for track use.
If you are honest with yourself and track the car to become a better driver, a compromise will work. If you go out there with zero instruction trying to win an HPDE trophy, you will melt the brake system down in a few laps.
I strongly urge anyone to go out with an instructor, and not a guy in a Miata, a guy that drives a Mustang, Camaro, Corvette etc. Let them drive your car for a few laps, so they no what the limit of the handling and braking is. Let them find the limit of the brake pad you choose, and how to react when you do, because you will find the limit at some point. Then we they are instructing you they can give you far better instruction on where to push and were to ease off.
That said, if budget is a concern, start with R10 Fronts, R8 rears, calm enough on the street, but handle about twice the temperature of the OEM pads. They are very rotor friendly for a race compound. You have a radio and power windows in case you ask about noise. You need brake cooling up front. Run a brake deflector at minumum, we carry Bamberg Engineering Deflectors. Ducted brake cooling is usually far more effective but is more complicated to install and requires regular maint.
If you have a more open budget run GS-1 pads all the time, and then when you have a track day you can put on R12/R10 compounds. This way the expensive race pads only wear out on track. You can just swap the day before and head to the event. The compound family is all cross compatible so there is not rotor preparation while swapping pads after the initial install. This will provide the best of both worlds, low rotor wear for all street driving, sufficient temperature for track use.
Front G-LOC Pads
Rear G-LOC Pads
Rotor Temperature Paint
We will have the Brake Cooling Deflectors on our website tomorrow.
