Whipple appreciate the tips.I had the same problem and found the part that fits for $1.51 (see picture with part number) at Advance Auto Parts. It was a real pain in the neck (literally) to get this little sucker installed. Couple of tips: 1. Do it while the car is running. When the car is off, a couple pushes of the brake pedal builds up pressure in the pedal and then you can't get the pedal to depress enough to make enough separation to get the rubber barb into the hole in the bracket. 2. It is almost impossible to install this using your fingers because of the angle of the bracket and the small space to work in. I doubled over some tape and attached the flat surface of the rubber part to the flat surface of a wood chisel with the tape. I inserted the tip of chisel with the small rubber part attached with the tape into the narrow space and used the chisel to push the barb into the small hole in the bracket. I wish I thought of these little tricks before fighting it for 10 minutes and working myself into a nasty sweat.
Just buy the $2 part from Advanced Auto as shown in Post #18 (or other source, maybe even Toyota, p/n 90541-06036 as shown in Post #12) and replace it yourself. Screw Ford and their shenanigans.Yes, they told me they had to replace the whole assembly because they dont just have that little $2 piece of plastic. Price quoted was $8??. With tax it would be over $900 closer to $1000! They have had the car for two weeks this coming Thursday. Numerous complaints to Ford, and they basically say tuff luck we are not doing anything. The local dealer said they will do the work and split the cost so $450 plus tax. Still unacceptable for what could be a fatal defect. I told my wife l should just drive it the way it is and when it gets rear ended, sue the hell out of Ford!
I just called my local Advanced Auto, gave them the Advanced Auto part number (N3121440809OES) and they said "We can order one in for you" ... I said yes, please do. For $1.51 it's worth having as a spare ready to go in case the original brake pedal stop pad breaks, which sounds pretty likely.I had the same problem and found the part that fits for $1.51 (see picture with part number) at Advance Auto Parts. It was a real pain in the neck (literally) to get this little sucker installed. Couple of tips: 1. Do it while the car is running. When the car is off, a couple pushes of the brake pedal builds up pressure in the pedal and then you can't get the pedal to depress enough to make enough separation to get the rubber barb into the hole in the bracket. 2. It is almost impossible to install this using your fingers because of the angle of the bracket and the small space to work in. I doubled over some tape and attached the flat surface of the rubber part to the flat surface of a wood chisel with the tape. I inserted the tip of chisel with the small rubber part attached with the tape into the narrow space and used the chisel to push the barb into the small hole in the bracket. I wish I thought of these little tricks before fighting it for 10 minutes and working myself into a nasty sweat.
Would if l could but had surgery last year to replace discs and still not fully healed. I know in the past when l replaced brake switches , l had to be a contortionist to get it done. Can't risk another surgery to my neck .Just buy the $2 part from Advanced Auto as shown in Post #18 (or other source, maybe even Toyota, p/n 90541-06036 as shown in Post #12) and replace it yourself. Screw Ford and their shenanigans.
https://www.amazon.com/Partsmart-Corporation-Clutch-Cushion-Corolla/dp/B07FC3QPFP
Maybe Dorman also has a replacement part.
If you have an Advanced Auto near you, have them order the $1.51 part discussed above in post #24 since we know it works. Then find a friend or a shop that can install it, definately don't risk hurting yourself. Hope you heal up well.Would if l could but had surgery last year to replace discs and still not fully healed. I know in the past when l replaced brake switches , l had to be a contortionist to get it done. Can't risk another surgery to my neck .
But may just take it to a shop with the part and have them install it.
I think what's happening is the ECU is programmed to cut throttle if it senses the brakes are applied, which it must think is happening when the brake lights are on. It stems back to the "runaway throttle" stuff that went on years ago with Toyotas. Car manufacturers are programming the ECU to cut the throttle when the brakes are applied in case the accelerator gets stuck for some reason (floor mat incidents like happened years ago) so that if the driver hits the brakes the engine power is cut way back so the brakes can take over and stop the vehicle.I would log an NHTSA complaint about that too.
If the brake pedal switch is tied into other systems besides the brake light function, that is definitely a safety concern when it fails as the OP and other member has noted, (especially if the driver is out on the highway).
