Body control Module.
pinero61
Houma, La
'15 Ruby Red Base GT PP
Need some help...
Trying to find and replace my BCM, but I cannot locate it on Tasca or in the car.
pinero61
pinero61
Houma, La
Exhaust shop welded on my car without isolating the battery, and caused a few issues.
I replaced the SRS module and ABS module already. They both accepted the new programming, but I'm still showing comms faults on the ABS module. The BCM should control the CAN comms on the system, so it's the next step in repairing this. Unfortunately, I do not have the equipment to flash it myself, so I'm troubleshooting through proxy.
FeedtheNeed
Virginia
2015 DIB GT Premium
There are two BCMs. I believe they are located one on each side of the car.
I couldn't find the actual part on fordparts.com, but it was in the image for another control module.
Part number 14B533 in the blow up image for a different control module from fordparts.com
http://www.fordparts.com/Commerce/P...search=true&year=2015&make=Ford&model=Mustang
I'm not certain this is what you're looking for, but I hope it helps.
pinero61
pinero61
Houma, La
Thanks, I'll run by the local dealer, and get it on the way.
rvlyssup
Vag...Gun...Stang-NUT
Palmdale...The High Desert of SoCal.
Rand
Lotsa...
Damn...how much welding did the shop do to fry all those modules?
pinero61
pinero61
Houma, La
Welded in the resonators and the 3" connections for my headers.
rvlyssup
Rand
Lotsa...
Hmm...curious, but isn't the shop suppose to take steps to make sure no electrical components get damaged?
Like properly grounding the car or disconnecting the battery...
347CobraII
iowa
2015 GT
You should see what happens when vehicles get hit by lightning.
pinero61
pinero61
Houma, La
Yes, but in this case they did not, and claim that welding with the battery connected cannot harm the vehicle.
ViolentDreams
Southern California
'99 Silverado - '15 Ecoboost
The car has 2 BCM's, the main one is located behind the passenger lower cowl trim panel, and BCM-B is located in the trunk on the passenger side behind the side trim panel.
BCM:
BCM-B:
pinero61
pinero61
Houma, La
Which of these controls CAN comm's for the ABS module and SRS module.
ViolentDreams
Southern California
The main one in the passenger footwell.
pinero61
pinero61
Houma, La
Thanks, I'll get one on the way.
pinero61
pinero61
Houma, La
