rvlyssup
Vag...Gun...Stang-NUT
- Apr 11, 2015
- Palmdale...The High Desert of SoCal.
- Rand
- Lotsa...
So...make a long story short, my TR005 heim joints are clunking again.
I've had RERS boots installed since the 1st clunking episode after about 500 miles after initial install. No issues since then @ about 2000 miles up until recently when they started clunking again. Other than some scoring on the ball surface, (nothing deep) the joint isn't loose. The ball wasn't rotating smooth (causing the clunking & as expected) so after I took everything apart yesterday, cleaned, lubed, and installed new boots...sad to say, the clunking is just as bad. Not sure if anyone running STEEDA's kit have this issue. :shrug:
Question I have is I'm thinking of getting new heim joints, either Teflon lined or greasable ones made by Rock Krawler, also anyone else with the same problem as me try these ideas out? I'm sure I can get new heim joints from BMR but I'd rather try something out that may be better or last a little longer. I dread the idea of going back to stock links. Any input would be appreciated. :cheers:
