BMR Tech Tip: Clock those bushings after lowering your S550!
Discussion in 'Suspension, Brakes & Chassis' started by BMR Tech, Feb 9, 2016.
  1. Biggsy
    Biggsy Well-Known Member
    First Name:
    Warren
    Vehicle(s):
    '17 GT PP, '02 4Runner
    May 3, 2018
    MD
    865
    434
    Rating:
    100%
    4   0   0
    I appreciate the response! But I'm already lowered and all that jazz but I'm switching my wheel/tire set up so I just want to know if the bushings have to be done again.
  2. Norm Peterson
    Norm Peterson corner barstool sitter
    First Name:
    Norm
    Vehicle(s):
    '08 GT #85, '19 WRX, '01 20AE
    Jul 22, 2013
    6,725
    2,806
    0   0   0
    Bushings only need to be reclocked when modifications cause a change in the inclinations of any arms or links that use OE bushings. Changing these inclinations without reclocking the bushings prestresses the bushings.
    It doesn't matter what's bolted up to the hubs (big tires, small tires, big steel plates), because that won't change any of the suspension's arm/link inclinations.
    Norm
    Biggsy likes this.
  3. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    2015 Guard GT Base, M/T
    Sep 21, 2014
    Naperville, IL
    15,025
    8,811
    Garage Profiles:
    Rating:
    100%
    3   0   0
    Short answer: no
    Biggsy likes this.
  4. Biggsy
    First Name:
    Warren
    Vehicle(s):
    May 3, 2018
    MD
    865
    434
    Rating:
    100%
    4   0   0
    Thanks guys. Didn't think so.
  5. HeelToeHero
    HeelToeHero Well-Known Member
    Vehicle(s):
    17 GT PP, 05 focus st
    Aug 17, 2016
    Ontario
    456
    114
    0   0   0
  6. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    15,025
    8,811
    Garage Profiles:
    Rating:
    100%
    3   0   0
    No.
    If you're not backing them all the way out, the threadlock remains intact. None of those bolts are torque-to-yield, so there's no reason not to reuse them. Ford is covering their butt.
  7. HoosierDaddy
    HoosierDaddy Well-Known Member
    First Name:
    Randy
    Vehicle(s):
    2016 GT Premium PP and a few others
    Jan 2, 2016
    5,179
    2,751
    Occupation:
    I could tell you but then I'd have to kill you
    Rating:
    100%
    2   0   0
    I take it you are talking about the dry thread-lock on part of the threads from the factory. I did a little research on that and have the impression it is activated by pressure when first tightened which made me wonder if it really still works after loosening. So I have been removing the dry thread-lock and using liquid thread-locker when reusing them which obviously requires them to be completely removed. Would rather not if the dry factory thread-lock is still working. I also wondered about how leaving the dry thread-locker on or using liquid effects how much torque should be used. I mean, the dry thread-locker must have an effect, so reuse or a different thread-locker might change that, although I have been assuming not enough to worry about.
  8. BmacIL
    BmacIL Enginerd
    Vehicle(s):
    Sep 21, 2014
    Naperville, IL
    15,025
    8,811
    Garage Profiles:
    Rating:
    100%
    3   0   0
    The primary and vast majority of the bolt retention is the stretch of the bolted joint when the bolt is torqued. The dry thread locker just adds some more friction, but a properly torqued bolt is what you need. In addition, the heat from the friction of threading in the joint will reactivate the compound.
    You don't need to worry about new bolts or thread lock when clocking bushings.
    HoosierDaddy likes this.
  9. Lowkeyslow
    Lowkeyslow Active Member
    First Name:
    David
    Vehicle(s):
    2019 Mustang GT
    Jul 27, 2019
    California
    i know this is a really old post but is there any pics/videos on this people know about? i'm not sure if i got everything!
  10. Dominant1
    Dominant1 Well-Known Member
    First Name:
    Dr Frankenstang
    Vehicle(s):
    2016 gt/cs auto 3:55 gears
    Jun 17, 2016
    2,799
    635
    0   0   0
    Digital_Synapse likes this.
  11. nrm101
    nrm101 Active Member
    First Name:
    Nathan
    Vehicle(s):
    2019 Mustang GT Premium
    Apr 3, 2020
    Mass
    Garage Profiles:
    Based on your comment, if you doing a wheel at a time are you suggesting disconnecting the sta-bar completely; Clock, and then reconnect? seems like that would have the desired effect?
  12. Norm Peterson
    First Name:
    Norm
    Vehicle(s):
    Jul 22, 2013
    6,725
    2,806
    0   0   0
    ^^^ should be better than not disconnecting the bar. Probably not quite as good as disconnecting both bars.
    Norm
Loading...
Share This Page
