Ghost50
- Sep 17, 2018
- Houston by way of Philadelphia
- 2019 Magnetic Metallic GT PP1
Cool thanks!No alignment needed when adding 762.
Great video!All new BMR CB762 kit installation for the ultimate IRS rigitity
While I don't know the answer to your question, you may want consider some other IRS upgrades. The RLCA bearings might be worth a look.BMR, I have an out of the box question maybe you can answer. I have Steeda subframe brace, Steeda subframe bushing inserts, Steeda, alignment kit & Steeda vertical links. I am wondering if knowing the way the Steeda subframe brace mounts & how it works would there be an added benefit to add just the rear braces of the BMR 762 kit to what I have? The rear feels solid but every once in a while I still get what I will call inconsistencies in the rear when turning & still feeling the IRS want to move around. I also get a slight amount of hop still. As much as I would love to get the BMR 005 & 762 I just dont feel like pulling all the front side of the IRS apart again & starting over. Also if they would help lock the subframe down a little more would yall sell just the rear braces of the 762 & if so how much? Thanks for any help & input. The car is a 19 PP1
The other part to consider in addition to what Bluemustang said is getting new tires. Once you put on a proper drag tire, the wheel hop concerns should be minimized (according to guys on here at least).BMR, I have an out of the box question maybe you can answer. I have Steeda subframe brace, Steeda subframe bushing inserts, Steeda, alignment kit & Steeda vertical links. I am wondering if knowing the way the Steeda subframe brace mounts & how it works would there be an added benefit to add just the rear braces of the BMR 762 kit to what I have? The rear feels solid but every once in a while I still get what I will call inconsistencies in the rear when turning & still feeling the IRS want to move around. I also get a slight amount of hop still. As much as I would love to get the BMR 005 & 762 I just dont feel like pulling all the front side of the IRS apart again & starting over. Also if they would help lock the subframe down a little more would yall sell just the rear braces of the 762 & if so how much? Thanks for any help & input. The car is a 19 PP1
I will consider that although I have PS4's for dd use & 26" MT dr's for the strip. I dont have any issues on the dr's at the track & for the most part it is sticks to the road very well on the PS4's. Just looking for something to cure the little bit of wiggle & hop that I have left, which isn't much. I know the answer would probably be pull the Steeda parts off & go all BMR but after the time & money I am just not sure I want to clear the board & start over so to speak. I will look into the bearings like stated above also.The other part to consider in addition to what Bluemustang said is getting new tires. Once you put on a proper drag tire, the wheel hop concerns should be minimized (according to guys on here at least).
Well, there's other factors contributing to wheel hop besides tires and subframe movement. Now whether the full BMR solution is that much better than the Steeda parts, I do not know. Someone more technically oriented might be able to shed light on this. That said, RLCA bearings and securing the diff mounts might serve you well.I will consider that although I have PS4's for dd use & 26" MT dr's for the strip. I dont have any issues on the dr's at the track & for the most part it is sticks to the road very well on the PS4's. Just looking for something to cure the little bit of wiggle & hop that I have left, which isn't much. I know the answer would probably be pull the Steeda parts off & go all BMR but after the time & money I am just not sure I want to clear the board & start over so to speak. I will look into the bearings like stated above also.
I echo your thoughts.Well, there's other factors contributing to wheel hop besides tires and subframe movement. Now whether the full BMR solution is that much better than the Steeda parts, I do not know. Someone more technically oriented might be able to shed light on this. That said, RLCA bearings and securing the diff mounts might serve you well.
