BMR Suspension offers new Vertical Links for the 2015-Newer Mustang TCA046/TCA047
BMR Suspension
Seffner, FL
2015 300A PP GT
TCA046/TCA047
BMR Suspension has expanded its line of billet aluminum Vertical Links for the 2015-newer S550 Mustangs, releasing Bearing/Delrin and Delrin/Delrin versions. Stock stamped steel vertical links with soft rubber bushings deflect under load, absorbing power and allowing excessive spindle rotation. Machined from 6061-T6 billet aluminum, the construction, heavy-duty spherical bearings, and Delrin bushings eliminate vertical link and bushing deflection. These solidly link the spindle to the lower control arm helping to reduce spindle rotation. The BMR Vertical Links (TCA046 – Bearing/Delrin, and TCA047 – Delrin/Delrin) will stand up to the high loads of any performance environment. The TCA046s and TCA047s give you the best in strength along with all of the bind-free suspension articulation needed for great handling. These are the perfect upgrade for the enthusiast looking to greatly improve performance without big increases in NVH. BMR designed the TCA046 and TCA047 to excel in street performance, drag race, and road race applications. The vertical link and bushing deflection is minimized, reducing rear wheel alignment changes and minimized rear spindle rotation. BMR Suspension’s TCA046 and TCA047 billet aluminum Vertical Links are black anodized for long-lasting good looks. Installation time is about 1 hour. Proudly made in the U.S.A.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
BMR Suspension
BMR Suspension
Seffner, FL
2015 300A PP GT
What are the differences between the two?
One has a Delrin bushing on one side and spherical bearing on the other (TCA046) and one has Delrin bushings on both sides (TCA047). The billet aluminum body is the same and the bearings/bushings are interchangeable.
