Advertisement
BMR Suspension New Product - S550 Motor Mount Brackets - MM008
Discussion in 'Suspension/Chassis/Brakes' started by BMR Suspension, Jun 29, 2017.
  1. RoyaalT
    RoyaalT Active Member
    Vehicle(s):
    2015 Roush Stage 2
    Jan 19, 2017
    Atlanta
    They weren’t designed to work together anyway.
  2. RoyaalT
    Vehicle(s):
    2015 Roush Stage 2
    Jan 19, 2017
    Atlanta
    One or the other should not and they both come with height adjustments (washers or polyurethane) to adjust back to stock height. By both I mean mounts and brackets
  3. RoyaalT
    Vehicle(s):
    2015 Roush Stage 2
    Jan 19, 2017
    Atlanta
    Doing both will
  4. Ricker
    Ricker Well-Known Member
    First Name:
    Ricky Rick
    Vehicle(s):
    Mustang
    Feb 16, 2019
    South Florida
    136
    46
    Rating:
    100%
    1   0   0
    Used on the 2018+ I would think that using adjustable mounts and these brackets together the max drop would still only be 1/2" because of the pan clearance.
    All that is needed is 1/2" and I want to ensure that this will indeed drop it a full 1/2" using the factory motor mounts.
    We are installing long tubes at the same time and don't want to have to drop the K-member to swap in adjustable motor mounts if these don't work out.
    It is for a street car and I am trying to avoid NVH.
  5. RoyaalT
    Vehicle(s):
    2015 Roush Stage 2
    Jan 19, 2017
    Atlanta
    Why would you use these if you are trying to avoid nvm?
  6. Ricker
    First Name:
    Ricky Rick
    Vehicle(s):
    Mustang
    Feb 16, 2019
    South Florida
    136
    46
    Rating:
    100%
    1   0   0
    With these you can lower the engine while utilizing the factory motor mounts.
    Theses brackets + factory motor mounts = no added NVH.
Loading...
Share This Page
