BMR Suspension MagneRide / GT350 Handling Springs: Pricing and Info!
Status
Not open for further replies.
Rodsaleen
Kansas
2018 Orange Fury Mustang GT
BMR Tech
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Figured I would share this review of our SPH765s on YouTube :)
Drpena13
2017 gt350
What size wheels and tires are on the white one after it’s dropped?
Ferrarokid
Northeast
T
2019 350r 2008 gt500 91lx 87gt
Just did the front bmr springs, cortex spherical, Vorshlag caster/camber plates & the car sits right at stock height.
Will try & post pics tomorrow, need to finish the rear links, bushings etc.
Ferrarokid
Northeast
T
2019 350r with the following : bmr springs (handling version) vorshlag camber plates, cortex monoball front & rear, bmr vertical links, full tilt boogie spherical toe bearings, bmr stage 1 subframe lockout, bmr centering sleeves.
so far car feels great, minmal nvh, letting it sit overnight before alignment.
DrumReaper
South East
So, quick summary:
1) Eibach - lowers the most, softest. For the most drop and softest ride.
2) Steeda - have both a progressive and dual-rate spring package. Progressive lowers the car the most ($240), dual-rate drops 3/4” ($300).
3) Ford Performance - modest drop, better performance, but progressive.
4) BMR - appears to be only linear package available with modest drop and rates > R stock spring setup. $300.
So, does this sum it up correctly?
Niz55
Us
17 GT350
So why did you even changed the front springs if you are back to stock ride height?
Ferrarokid
Northeast
T
It’s about 1/8” lower after settling, with a linear rate that’s a few pounds stiffer then stock r spring.
madweazl
Fredericksburg, VA
'19 GT350
Are these still dropping the front by .3" and the rear by .5" on the '19-20 350 or was there a change?
Jamongkad
Sacramento, CA
Mathew
2019 GT350
Question has anyone tried installing front BMR springs paired with stock rear springs on a 2019 GT350? Interested to know if this is a good combo.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
You'll have a ride height issue since these lower the car. My recommendation would be to do both
Status
