NickBlack
Bought for $200
Selling for $185 free shipping (shipping is gonna cost me around $35 bucks)
Selling my brand new, never installed BMR IRS Subframe Support Brace System - CB762
Selling the Mustang so hope these can be put to good use. They are awesome for the S550 chassis to get better traction and cornering!
New in box, only opened to take photos.
https://www.bmrsuspension.com/?page=products&productid=1910&desktop=1
- 4-piece IRS Bracing System, most thorough IRS Bracing System Available
- Reduces IRS Movement and IRS Assembly Deflection
- Compatible with BMR and other IRS Modifications / Mounting Solutions
- Zero decrease in ground clearance
- Extremely easy bolt-on installation
- Works better than any other bracing solution when used alone as a single product
- Reinforces critical areas of the IRS Subframe by reducing leverage
- High-Quality hardware for installation included
Info: After a few years of drawing parts up, making prototypes and testing, BMR finally came to a design in which they feel is as "good as it gets" when relying on bracing to add additional rigidity to the IRS-to-Chassis mounting. ADDITIONALLY, the CB762 kit adds additional reinforcement to the IRS Subframe itself by tying in to the front leg of the subframe where the leverage is reduced on the component. This area sees significant loads as it is directly in front of the Front Rear Lower Arm pivot point and just rearward of the front Subframe-to-chassis mounting point. In the rear we take the "zero movement" approach by mounting a SUPER heavy-duty plate beneath the sway-bar mounts and we then tie that into the rear bushing mount - it is locked SOLID. This rear mounting method ensures the rear of the IRS subframe does not move or drop at all under heavy loads, which in-turn helps with the movement of the overall system by reducing twist loads on the front mounts.
Thanks,
Nick
Thanks,
Nick
