Bluemustang
Not a bad idea Biggsy.I know it cost more but I would consider Vorshlag mounts as it give you some shock travel back.
Thanks man. Can't wait to test it out more! The front struts are slotted so the tech said he tried to use it to max out the camber and well, the tire was rubbing the strut. So he went back and adjusted it at the plate so I have clearance to the strut now and he thinks there's more room to get more camber.Glad you had a great first impression!!! I'm looking forwarded to getting mine
BTW, do you know how the shop did the camber? (maxed in the plate & adjusted at the spindle, or vice versa). And did they say anything about the wheel-to-strut clearance?
If I didn't have those Steeda extended balljoint control arms, I believe I could get over -3 pretty easily. The tech seems to think i can get to -3 but I kinda doubt it. Also, the passenger side top nut is pretty close to the strut tower hole, but it sits underneath it so maybe can get a bit more before I'm limited by that.
If you had dimensions of the shaft, I could have made an adapter. Possiblythe Steeda rear shock mounts - yeah, they don't fit
My shop attempted to do that but they did not like the result. But no worries. J&M and Vorshlag have solutions for me. I'll address it at some point here.If you had dimensions of the shaft, I could have made an adapter. Possibly
