Motobrat95
Coming from the Genesis community, Modding is a very popular thing. You have your stage 1, stage 2, and stage 3 being some of the common references of how modded you are.
Well to get to the point the 2.0 in the genesis world isnt the strongest thing out there, but a stage 3 (full bolt ons and turbo swap) using a Gt30 (22-22psi) or similar will pump out a safe 380-400Whp and 300-310Wtq (low torque to save internals) on stock fuel system .
Not knowing much about the ecoboost world, Im assuming they are a well built motor and if i understand the 2.3 has some strong internals such as forged crankshaft and rods. If Hyundais can pump out those good of numbers with a simple swap, I see no reason why the eco2.3 with more displacement and better internals cant see 400+whp on a simple gt30 swap safely.
I know the manifold is integrated into the block, but a simple adapter plate or pipe should fix that. Ive also read about a few 2.0eco ??? fusions pumping out 400whp on a turbo swap... Just something to think about, what are your thoughts ?
