Better air + better tires = PB
brucelinc
MN
Bruce
2018 Mustang GT premium A10 (SOLD)
I got to the track and mounted up my MT ET street R tires. Fortunately, it was a cooler day than the last time I ran. FINALLY I was able to run without violent wheel hop on the 1-2 shift. I know the 60s are not very good. That was strictly driver caution. I didn't know how the tires would hook and my track is 110 miles from home so I was pretty gentle on the launch. With more aggression, I think 11.8s or maybe even better might be possible. We had a stiff side wind but, otherwise, the air was good.
bluebeastsrt
Oh boy
New Jersey
BigD
Ruby red 2019 GT Premium.
Id say 11.5 are possible. Plenty left in the sixty.
brucelinc
brucelinc
MN
Bruce
I was just happy not to get any wheel hop. That was my biggest problem with my stock tires. I love the way the drag radials cured that problem. Bluebeast, I know you like to see wider and taller tires but I think with no power adders the 275/40-17s worked fine. The lower height actually gives me the equivalent of a 3.70 gear even though the car has a 3.55. They do look a bit small but they hook well.
Stang Racer
Ohio
Tom
2019 Mustang GT A10 301A
Nice! Any mods other than tires?
brucelinc
brucelinc
MN
Bruce
CB005 and vertical links. I had those before and still had wheel hop with stock Pirellis. The Mickeys combined with the suspension mods and the better air was all I needed to cut 4 tenths off my previous best.
I am planning on an E85 tune at some point....probably not until next season.
Blown86GT
Central FL
MPH is killing it. Almost 120 on one run..
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
Nice!!!
I went and got the same rear wheels as you and had my Hoosier 28x10 17's mounted today.
May run tomorrow....
Turbolag87
Toronto
My18 gt
mods?
brucelinc
brucelinc
MN
Bruce
CB005, vertical links, drag radials. This is the first time I could actually use drag mode. With the stock tires, it would just wheel hop on the 1-2 shift and sometimes even shut down the engine or force a shift to 3rd prematurely. The drag radials solved the problem.
The other "mod" that made a lot of difference was DA around 300 rather than the 2500-3000 I was running in last month.
Stang Racer
Ohio
Tom
Thanks... did you make this run in Drag Mode if you have that option?
brucelinc
brucelinc
MN
Bruce
I used drag mode. First time I could use it without the IRS going crazy. I got a little bit of wheelspin on the 1-2 shift but no hop. I had 20 PSI in the tires. Probably should have lowered that some.
RBELUN
TEXAS
2018 GT P1
nice run indeed and good to know about the tire choice.
Triton54
Delano Mn.
Greg
18 GT A-10 (mine) 17 GT pp, 6spd (wifes)
Very nice Bruce!! i have not been to rockfalls since the early 2000's (03) i think, with a 2000 Lightning! very nice time slips!!!
poncho@home
GettingOld
Laval, QC
2017 Mustang GT Premium
Nce runs! Should go deep 11.7s with better 60’.
