I got the 72” ones.race ramps are really niceRace Ramps has an extended version that will work.
Edit, these: https://www.raceramps.com/ramps/race/p/rr-xt/
Yeah, it's important to get the right height on the jack stands without going too high. I prefer my 3-ton jacks as they seem to be just the right size overall and I've got the height dialed in just right.All I would suggest is take your time and don't try to go to far up on jacking one side to put on jack stands. Before I got quik Jacks, I jacked up one side and tried to put one side on 4 ton jacks. The car did the jack stand shuffle. I let it back down Slowly and ordered Quik Jack for when I need the car fully off the ground to work underneath. I also have BMR Low profile rails and love them, Good Choice.
It really depends on your needs! For me, jack stands are a necessity since I swap my rotors and pads before and after every track day, so cribs won't work for me.that is why i do not use jack stands. the car is more stable with these car cribs, easy to make and affortable, plus your suspension is not stressed
I did the same for exactly the same reasons. Don't feel as comfortable crawling under a car on jack stands as when I was younger....bought jack rails, found mid point to jack car up evenly on one side and place " car cribs" under each tire. repeaded process on the other side. was able to raise the car up 2 feet, giving me plenty of room to install LTH. With this method your suspention is not under extended stress. Works great and completly safe! I built these cribs using 2x4's supper easy.
To what length did you cut these 2x4s?bought jack rails, found mid point to jack car up evenly on one side and place " car cribs" under each tire. repeaded process on the other side. was able to raise the car up 2 feet, giving me plenty of room to install LTH. With this method your suspention is not under extended stress. Works great and completly safe! I built these cribs using 2x4's supper easy.
I installed the Steeda jack rails on my convertible and they work great. I put the jack in the middle of the jack rail and jack up one side of the car at a time and put jack stands under the front and rear of the jack rails. Then i move to the other side of the car and do the same thing. I also use ramps depending on what I'm trying to do.Im looking for guidance on how to safely raise my Mach 1 on jack stands using a standard floor jack. I will install jacking rails and change the oil. I will also inspect the undercarriage for loose bolts as I tend to get knocking at low speeds when I modulate the throttle. Is it safe to do one whole side first and then the other? Im thinking of driving over wood boards on all corners to help get additional clearance to do a midline approach. Suggestions appreciated.
If all four tires are sitting on cribs there's no need for anything else. It's literally the same stability (assuming well constructed cribs) as the car sitting on the ground. Think of it kind of like a mechanics pit.To what length did you cut these 2x4s?
Also, I can’t tell from the picture if the car is standing ONLY on FOUR of these “car cribs,” or do you have something additional in the middle as well?
