Best way to get bass to pass into cabin from the trunk besides folding the rear seat backs down?
Chef jpd
Brooklyn, NY
Ok, finally got a pic of the modified seat latch.
It is now on top of the carpet with 3/4 inch spacers under it.
Enjoying much tighter and harder hitting bass.
20190926_194804 by chefjpd, on Flickr
Shane361
Charleston, SC
Shane
2015 Competition Orange Procharged GT
Going to do any mids/highs? I'm currently changing mine up and going with JL Audio C2 Comps up front, removing center and door 3.5's. Going with JL Audio C2 Coax 6.5's in the rear deck with an LC7i and Jl Amp for mids/highs. Plenty of bass with my 12" Sundown and JL1000.
FreePenguin
Ohio
Donald
17 mustang
I’m going to try this soon, do you notice the seats being down at all? The gap?
still glad you did it?
I don’t really know what a spacer is, can someone post a pic of what I should look for at Lowe’s, is it a bolt or cylinder or something?
The spacers are under the carpet correct, the brackets on top now?
Chef jpd
Brooklyn, NY
FreePenguin
Ohio
Donald
17 mustang
When in passenger/driver and look back. You don’t even see a gap do ya?
Chef jpd
Brooklyn, NY
Not visible at all. And you could modify both rear seats if the OCD is acting up.
FreePenguin
Ohio
Donald
17 mustang
Planning on doing both this week. Thanks!
Chef jpd
Brooklyn, NY
Fyi, the bolts required are M8-1.25, 60mm
Andy13186
Probably helps with exhaust sound too I would think.
FreePenguin
Ohio
Donald
17 mustang
I put a little superglue on all the screws and tightened the shelf speakers up, they was completely loose from vibrations and driving, tossed a drop super glue on each one. Shouldn’t get loose again
I had a rattle I couldn’t place it, it was a speaker that got lose.
so put the seat latches on top of the carpet with the spacers behind it? Any reason why didn’t put both spacer and latch behind the carpet?
Just trying to make sure doing it right when I get the bolts tomorrow
looks awful but tossed some dynamat extreme up there
FreePenguin
Ohio
Donald
17 mustang
Edit. Is the carpet flat against metal, and spacer is simply under the bracket on top of carpet? Gotcha. Just looked closely at pics
doing both tomorrow. Hoping bass comes through more solid with the seats down the car jams. But I hate the down seat look
if you could explain tomorrow would be great. I am under assumption I need 4 spacers, and 4 bolts. Grabbing ASAP in morning
Chef jpd
Brooklyn, NY
Yes, 4 spacers and 4 bolts.
The hole in the carpet is only big enough for the latch loop to poke through, so you will have to enlarge the hole to accommodate the new bolts.
the spacers will then go between the body and the plate, holding it solid.
FreePenguin
Ohio
Donald
17 mustang
I’m doing it in like two hours.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
As in, using a hole saw to swiss cheese the plastic? Please post some pictures, I've been thinking about doing this or cutting out a section and replacing with a perforated metal panel or something like that.
