MPotter
Or plug/re-route... Keep that frothy oil/water mix out of my engine, if you please.Looks like that catch can has a drain hose to send the collected oil back into the engine.
Aftermarket ford did the same thing with the gt350, pre production cars they all had oil separators. Watch the motortrend review you can see them on the dynoYou are correct. I was trying to figure out what that was, considering the position, but as soon as I read your post, I was like yeah! I see it clearly now. So next question, stock or aftermarket ?
They’re paintedAre the cam covers gray plastic or aluminum/magnesium?
I don't believe that to be correct. Engine elevation, say the longitudinal crank centerline, would be no different on a new GT500 than a new GT350 or an older GT500. The height is driven by oil pan ground clearance, clearance between the oil pan and the steering rack and crossmember, exhaust clearance starting at the cylinder heads on down and then back, and the fact that the transmission height from the ground is directly related to that of the engine (which then dictates driveshaft height relative to the ground, exhaust clearance, and has an impact on driveline angles).That engine is sitting real low compared to the older GT500s. Lower center of gravity, better handling.
If you look closely at some of the development cars that were captured with their hoods open you can see the cables exiting the same location as all other S550 cars. That being, passenger side, between the strut tower and the firewall, hidden behind removable cladding.So , where is the battery located ?
Makes sense. I suppose because the blower's height is lower, it made the whole engine look like is lower.What is lower is the blower case relative to the engine. Ford has stated that they lowered it such that it's center of gravity was as low as possible which helps to mimize the potential impact it has on certain vehicle dynamics.
To the left of the separator- you can see a ground running back to that location.So , where is the battery located ?
Except those separators were "Bob's" units and not FR designed separators. The one showing on the 2020 GT500 says Ford Performance on its top half.Aftermarket ford did the same thing with the gt350, pre production cars they all had oil separators. Watch the motortrend review you can see them on the dyno
Yeah, I'm sure it'll come in handy in someones collection.Look closely. The above GT500 is sporting a passenger side oil separator, a rather large one at that.
