Are there aftermarket valves for the Gen3 coyote?Still on stock valves here!
Thanks, for whatever reason I didn't see them in Manley's online catalog. You'll still need to adjust the CH of the piston and ring package to account for the change of the pin location though. For FI, in this case, you'll get a higher CH for the piston which means the top land can be thicker than a stock piston.These are 5.85 length
https://www.modularheadshop.com/i-2...eam-connecting-rods.html?ref=category:1271340
@Tiago G.
Is that what you got .
There is also this which is $$$
I think I have a problem .
I am drooling over these rods
The Oliver ones seem most reasonably priced at less than $1400 . Lol
... must resist .
https://www.modularheadshop.com/c-1...g-rods-4-6l-5-0l-stroker-connecting-rods.html
Yep, Those should be the ones. Manley Pro series in 300 M for forced induction.These are 5.85 length
@Tiago G.
Did, you ask them to port and polish the heads while in there? LMAO, Does it ever end?I agree on replacing the valves on a high end build. Why risk a low dollar part (in the grand scheme of things) potentially killing a $25,000 engine?
I run Ferrea valves on my 1300whp Procharged Coyote
One of the things is that each builder have parts of their choice. I mentioned Olivers to them before but it seems that the Manleys are doing an amazing job for these engines either with the Turbo Tough or the Pro series and it was very clear to me they are the brand of choice at BES.I think I have a problem .
... must resist .
If you are going to build a stroker with the 3.8 or 3.9 callies crank you won't be able to go with the H turbo Tough rods.I just bought a gen3 5.2 block to build, Im debating using the H tuff rods and extreme duty pistons or doing molnar powr adder rods with diamond 2k pistons. I dont know what to order, I want to live at 1k wheel with my Gen3r.
No, I never did.@Tiago G.
Did you consider using a predator block ?
I know BES are not a fan of the PTWA liner .
Cost of new predator block is about the same cost to sleeve your Gen3 coyote .
No.So do you thing it would be more cost effective ( if we can call that at this point haha) to just have the fully assembled GT350 heads installed on my Gen III or it would require extensive machining and other things to make it work?? My build is another 8-10 weeks away so I still have time to pull the trigger and make new decisions on a few things.
baaahhh, I forgot about the D.I. lolNo.
First of all the GT 350 heads wont work in a Gen3 - no DI
Second ,even if you could figure a way to make them work , I dont think they are worth the premium and have their own issues, related to oiling. They also require relatively expensive followers (not as expensive as Gen 3 coyote though) and cams .
Are you using GT 350 heads in your build ?With that being said, that's why I've decided to simply run gen 2 restrictors/pump.
Pac with titanium retainerswhich valve springs did you get ?
Running my gen2 headsAre you using GT 350 heads in your build ?
