Superspirit
You figured it out before I could help, awesome. 727-01-01 does not get changed unless you're installing an amp and want pre out signals. 727-01-02 fixes the eq curve.OK I had also changed 727-01-01, from info found elsewhere online. Changed that back to the original values and now the radio is much better.
Also the B9 mentioned in my earlier post turned out to be the checksum automatically calculated by Forscan.
Finally, found a program online called “AsBuiltExplorer” and was able to use it to view my factory as-built (.ab) file downloaded from Ford.
