Benefits of 10 speed over MT82 for drag racing
Discussion in 'Dragstrip and Launching' started by [email protected], Jan 23, 2020.
  1. poncho@home
    [email protected] GettingOld
    Vehicle(s):
    2017 Mustang GT Premium
    Sep 19, 2017
    Laval, QC
    577
    185
    0   0   0
    Here are 3 images demonstrating why the 2018+ 10 speed GTs are just so damn quick. And yes, I agree the actual shift time is quicker on the auto, but its clear that the time spent near peak power is what really makes the difference and why the MPH so high.
    I can also see a small benefit from the 2018 MT82 vs the 2015-17 with one less shift needed.
    So even getting a 2015-17 to similar power levels @460 CHP, the transmission gearing advantage of the 10 speed is hard to make up.
    BTW I own a 2017 MT82 and I have no regrets, just an observation. If I were interested in only drag racing, I'd likely sell mine and buy a new 10 speed, but I just loving shifting gears when out for drives.
    https://imgur.com/a/5Q9iGQh
  2. Zinc03svt
    Zinc03svt Well-Known Member
    Vehicle(s):
    stang
    Jun 3, 2018
    usa
    2,311
    1,199
    0   0   0
    Yes. Mine basically goes from 7500 to 6500 every shift. Very effective use of powerband plus wot shifts.
    jmeiers and brucelinc like this.
  3. jmeiers
    jmeiers Well-Known Member
    Vehicle(s):
    2019 Mustang GT PP1/401A/A10
    Oct 27, 2018
    Northern Virginia
    415
    178
    Garage Profiles:
    Rating:
    100%
    1   0   0
    Enough said! I have had 5 other Mustangs over the last 25 years with 5/6 speeds and do not miss any of them, especially in traffic. I could never manually shift this fast in my wildest dreams.
    Andy13186 and Zinc03svt like this.
  4. Zinc03svt
    Vehicle(s):
    stang
    Jun 3, 2018
    usa
    2,311
    1,199
    0   0   0
    Yeah the A10 punches higher up in the food chain for sure. Nasty from a roll.
    LongStroke likes this.
  5. Braski
    Braski Well-Known Member
    Vehicle(s):
    Traded 2015 Blk GT Prem PP on 2019 Corvette GS 2LT M7
    Feb 4, 2015
    Lancaster, PA
    2,082
    933
    Garage Profiles:
    Rating:
    100%
    2   0   0
    NA A10 and E85 is a nasty combo!
    Zinc03svt likes this.
  6. LETHAL
    LETHAL From the D but in the NC
    First Name:
    Kevin
    Vehicle(s):
    2018 GT A10
    Sep 26, 2015
    Asheville, NC
    1,644
    543
    Garage Profiles:
    Rating:
    100%
    4   0   0
    Rolls are flat out NASTY... esp after being tuned.
  7. NASteve
    NASteve Member
    First Name:
    Vehicle(s):
    2019 Mustang GT
    Sep 11, 2019
    Conroe, Tx
    Minimizing rpm drop and keeping it in the upper rpm band along with consistent shifts and the speed at which is switches gears is all major advantages. Add in a higher stall converter and really you'd be dumb not to use a A10, with that said I'm dumb because I have a MT82, but should this ever get serious enough and I wanted to stay manual I'd just order up a liberty 5 speed and bang gears that way, but the car would never see street use again.
  8. ponie1992
    ponie1992 Well-Known Member
    Vehicle(s):
    2016 Ruby Red PP GT
    Jan 4, 2016
    Elgin, SC
    1,443
    362
    0   0   0
    I'm running a T56 Magnum. We'll see how it goes.
  9. Andy13186
    Andy13186 Well-Known Member
    Vehicle(s):
    2018 Mustang GT 10speed
    Sep 19, 2018
    1,264
    439
    0   0   0
    It looks like it may be beneficial to move the shift point of first and 2nd on the 10r80 cars up as high as you are comfortable with, am I correct? Youd be entering 2nd and 3rd with more power if you revved first and 2nd out higher.
  10. jmeiers
    Vehicle(s):
    Oct 27, 2018
    Northern Virginia
    415
    178
    Garage Profiles:
    Rating:
    100%
    1   0   0
    Mine is set to shift at 7800 rpms via Palm Beach Dyno. Verified via datalogging.
    Cory S likes this.
  11. Andy13186
    Vehicle(s):
    Sep 19, 2018
    1,264
    439
    0   0   0
    I think thats too high for the rest of the gears since you make more HP around 6000 than above 7500. In the OP's graph you can see 1-2 drops the RPMS to 4700 and 2-3 drops it to 5300 , the rest all drop above 6k even with the stock 7400 shift point.
    This is an e85 2018 dyno you can see there is actually more power made at 6000 than 7600. So at this point I think 7800+ is good for 1-2 and 2-3 but 7500 is best for 3-4-5-6-7. I may have them modify my shift points for 1-2 and 2-3, or try paddle shifting it and see if I get good results wringing out first and 2nd more. There is more torque though at the lower shift points not sure if that really matters. PBD sets your actual rev limiter to 8200 btw which is kind of insane but you never hit the limiter unless you accidently leave it in paddle mode, which is kind of awesome.
    Cory S likes this.
Loading...
Share This Page
